Postby ESP_Frank » Fri May 20, 2022 6:03 pm
I think I understand what is going wrong, but don't know how to solve it.
I found out that ESP8266 sends an initial Random during Client Hello with UNIX Timestamp 00000000 (=Jan 1, 1970 01:00:00.000000000). This is outside the web server certificate's time frame and may be a reason for the web server to reject the connection.
I am using an ESP8266 containing:
AT version:1.7.5.0(Oct 9 2021 09:26:04)
SDK version:3.0.5(b29dcd3)
compile time:Oct 15 2021 18:05:38
Bin version(Wroom 02):1.7.5
Before sending AT+CIPSTART="SSL","servername",443 I did configure SNTP using AT+CIPSNTPCFG=1,1,"pool.ntp.org" and issued a successful SNTP request with AT+CIPSNTPTIME?. But still the time info in the Random remains 0. See wireshark extract below:
Handshake Protocol: Client Hello
Handshake Type: Client Hello (1)
Length: 47
Version: TLS 1.1 (0x0302)
Random: 000000006606ced024c458f0afad29b242403955b02a121fd48d0fc83c452f44
GMT Unix Time: (0)Jan 1, 1970 01:00:00.000000000
Random Bytes: 6606ced024c458f0afad29b242403955b02a121fd48d0fc83c452f44
Session ID Length: 0
Cipher Suites Length: 8
Cipher Suites (4 suites)
Cipher Suite: TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
Cipher Suite: TLS_RSA_WITH_AES_256_CBC_SHA (0x0035)
Cipher Suite: TLS_RSA_WITH_RC4_128_SHA (0x0005)
Cipher Suite: TLS_RSA_WITH_RC4_128_MD5 (0x0004)
The (Apache) webserver is allowing TLSv1.1, but responds with:
Transport Layer Security
TLSv1.1 Record Layer: Alert (Level: Fatal, Description: Handshake Failure)
Content Type: Alert (21)
Length: 2
Alert Message
Level: Fatal (2)
Description: Handshake Failure (40)
To test what happens if the Apache server does NOT accept TLSv1.1 I temporarily modified the server's SSL configuration. Then it responds as follows:
TLSv1.1 Record Layer: Alert (Level: Fatal, Description: Protocol Version)
Length: 2
Alert Message
Level: Fatal (2)
Description: Protocol Version (70)
So it indicates reject because of the used TLS protocol version.
The server also accepts ciphers TLS_RSA_WITH_AES_128_CBC_SHA and TLS_RSA_WITH_AES_256_CBC_SHA, so this is probably not the reason for handshake failure.
So I have the strong impression that the wrong time stamp is the reason for the failed SSL connections. Any idea how this can be solved?
Thanks!
