esp8266 can connect to server only once evry time
mikewang
Postby mikewang » Fri Apr 10, 2015 4:43 pm
as mentioned in subject , after powered on , the soc can connect to the server and post related command with response recieved from server by http, and then the server diconnect the tcp connection. as all u know , soc goona run to disconnect_callback and call reconnect so that the soc can connect to the server again.
here is the problem, once the server disconnect connection, soc run to “user_esp_platform_connect” as shown in the log below and then blocks here or just restarts
i just can not figure out the reason, so the problem is just brought up here ,i am really long for your response.
thanks
the last part of log information from serial:
user_esp_platform_reconnect
user_esp_platform_dns_found 114.80.0.226
sometimes i becomes fatal exception:
Fatal exception (9):
epc1=0x401006d4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00e0f7ae, depc=0x00000000
epc1=0x4010058e, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00e0f7b2, depc=0x00000000
Re: esp8266 can connect to server only once evry time
Postby ESP_Faye » Sun Apr 12, 2015 5:48 pm
Could you offer us the test code to replicate your problem?
mikewang
Postby mikewang » Thu Apr 30, 2015 1:08 pm
Espressif_Faye wrote:Hi,
thanks for ur replay ,finally it is the bug of my own code,really sorry
Users browsing this forum: No registered users and 35 guests
