TCP client mode - auto re-connect ?
nccchirag
Postby nccchirag » Sat Apr 11, 2015 9:06 pm
ESP - TCP Client
Embedded Linux Server - TCP Server
if the tcp client on ESP is disconnected from server, how to enable auto reconnect ?
kindly guide
Re: TCP client mode - auto re-connect ?
Postby ESP_Faye » Mon Apr 13, 2015 2:43 pm
So sorry that there is no auto reconncet.
You could call espconn_connect in espconn_disconnect_callback(normal disconnect) or espconn_reconnect_callback(abnormal disconnect) to reconnect TCP server.
nccchirag
Postby nccchirag » Mon Apr 13, 2015 3:27 pm
this would require a custom firmware compilation (based on 0.9.5) rt ?
Postby ESP_Faye » Mon Apr 20, 2015 2:13 pm
Yes, do you mean using AT commands ?
Call AT+CIPSTART to create a TCP connection again, if message about disconnection is received.
nccchirag
Postby nccchirag » Mon May 04, 2015 10:40 pm
with AT commands, AT+CIPSTART would have to be issued by the MCU
can the SDK take care of the auto re-connection ... ?
eg. firmware would autoconnect to wireless router if it is rebooted .. but the TCP connection would have to be manually initiated from the MCU via AT command
