No heap available error
JeroenVH
Postby JeroenVH » Wed Mar 29, 2017 11:49 pm
Hi Espressif,
I am currently trying to build a connected e-ink display based on the ESP12 and the design found on http://spritesmods.com/?art=einkdisplay. I've managed to show bitmaps from the file system on the screen, but when I connect to a server, it doesn't work due to a "No heap available, failed to malloc 1592" error. I looked this up and found http://bbs.espressif.com/viewtopic.php?t=570, but the fix does not work in this case. Is there any known bug that would cause this? I get the error even with the original code from spritesmods, so it appears to me as if this might be an issue somewhere with the SDK. Below, I have included the output I get when running from a reset (not a power up).
mode : sta(5c:cf:7f:f8:45:d1)
add if0
scandone
reconnect
scandone
add 0
aid 1
pm open phy_2,type:2 0 0
cnt
connected with Jerre, channel 1
dhcp client start...
ip:192.168.43.189,mask:255.255.255.0,gw:192.168.43.1
httpclient: found ip. Connecting to host meuk.spritesserver.nl port 80 path /espbm.php
Connected.
httpclient: GET /espbm.php HTTP/1.0
Host: meuk.spritesserver.nl
Connection: close
x-battery-mv: 3617
x-mac: 5c:cf:7f:f8:45:d1
Wdt. This takes too long. Go to sleep.
del if0
usl
sul 3 0
rm mismatch
pm close 7 0 0/17964040
No heap available, failed to malloc 440
deep sleep 60s
Kind regards,
Jeroen
Re: No heap available error
Postby pratik » Sat Apr 01, 2017 12:03 am
This debug output seems to say that the heap memory (free RAM which is allocated via dynamic memory allocation functions) is deficient. The first thing I would suspect here is that there are memory leaks in the program. i.e. you are allocating memory using os_malloc, etc and you are not freeing them using os_free API.
That could be why you are repeatedly getting the heap error. Maybe a loop is going on endlessly or something.
Please check that and let me know if it worked.
Users browsing this forum: No registered users and 334 guests
