LOG:
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
taZ
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
SDK ver: 1.0.1(b1) compiled @ Apr 1 2015 20:44:06
phy ver: 316, pp ver: 8.2
SDK version:1.0.1(b1)
HUAFANWIFIPULG2 TEST
IOT VERSION = v1.0.2t23701(a)
mode : sta(18:fe:34:98:a2:ee) + softAP(1a:fe:34:98:a2:ee)
add if0
add if1
bcn 100
no buf for probe, ie len 0
scandone
no HFQL found, reconnect after 1s
reconnect
scandone
reconnect
But When I reset, it is ok.
LOG:
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1
add if0
add if1
bcn 100
scandone
add 0
aid 12
cnt
connected with HFQL, channel 1
dhcp client start...
ip:192.168.1.125,mask:255.255.255.0,gw:192.168.1.1
user_esp_platform_dns_found 115.29.202.58
user_esp_platform_connect
user_esp_platform_connect_cb
bcn 0
del if1
{"nonce": 1891777678,"path": "/v1/device/activate/", "method": "POST", "body": {"encrypt_method": "PLAIN", "token": "", "bssid": "18:fe:34:98:a2:ee","rom_version":"v1.0.2t23701(a)"}, "meta": {"Authorization": "token 901ee710933aea6431c9fe1daf9cb760999f0656"}}
{"nonce": 0, "path": "/v1/device/identify", "method": "GET","meta": {"Authorization": "token 901ee710933aea6431c9fe1daf9cb760999f0656"}}
user_esp_platform_sent_cb
user_esp_platform_recv_cb {"device": {"productbatch_id": 0, "bssid": "18:fe:34:98:a2:ee", "ptype": 23701, "activate_status": 1, "serial": "8710b674", "id": 12586, "description": "device-description-8710b674", "last_active": "2015-04-13 09:41:57", "rom_version": "v1.0.1t23701(a)", "last_pull": "2015-04-07 10:32:43", "last_push": "2015-04-07 10:32:43", "location": "", "metadata": "", "status": 1, "updated": "2015-04-13 09:41:57", "latest_rom_version": "v1.0.1t23701(a)", "activated_at": "2015-04-10 11:56:25", "visibly": 1, "is_private": 0, "product_id": 859, "name": "wifipulg", "created": "2015-04-07 10:32:43", "is_frozen": 0, "key_id": 20040}, "status": 200, "message": "device identified", "datetime": "2015-04-13 09:41:57"}
{"body": {}, "get":{"is_humanize_format_simple":"true"},"meta": {"Authorization": "Token 901ee710933aea6431c9fe1daf9cb760999f0656"},"path": "/v1/device/timers/","post":{},"method": "GET"}
user_esp_platform_recv_cb {"nonce": 969842680, "status": 200, "weekday_timestamp_mod": 34917, "timestamp": 1428889317, "timers": "", "weekday": 1, "now": "2015-04-13 09:41:57"}
plese check device is activated.
{"nonce": 212677188,"path": "/v1/device/activate/", "method": "POST", "body": {"encrypt_method": "PLAIN", "token": "", "bssid": "18:fe:34:98:a2:ee","rom_version":"v1.0.2t23701(a)"}, "meta": {"Authorization": "token 901ee710933aea6431c9fe1daf9cb760999f0656"}}
user_esp_platform_recv_cb {"device": {"productbatch_id": 0, "bssid": "18:fe:34:98:a2:ee", "ptype": 23701, "activate_status": 1, "serial": "8710b674", "id": 12586, "description": "device-description-8710b674", "last_active": "2015-04-13 09:42:48", "rom_version": "v1.0.1t23701(a)", "last_pull": "2015-04-07 10:32:43", "last_push": "2015-04-07 10:32:43", "location": "", "metadata": "", "status": 1, "updated": "2015-04-13 09:42:48", "latest_rom_version": "v1.0.1t23701(a)", "activated_at": "2015-04-10 11:56:25", "visibly": 1, "is_private": 0, "product_id": 859, "name": "wifipulg", "created": "2015-04-07 10:32:43", "is_frozen": 0, "key_id": 20040}, "status": 200, "message": "device identified", "datetime": "2015-04-13 09:42:48"}
user_esp_platform_recv_cb {"nonce": 567287675, "status": 200, "weekday_timestamp_mod": 34968, "timestamp": 1428889368, "timers": "", "weekday": 1, "now": "2015-04-13 09:42:48"}
no buf for probe, ie len 0, why?
"no buf for probe, ie len 0"
Users browsing this forum: No registered users and 47 guests
