build error using peripheral_test code
shenhome
Postby shenhome » Thu Apr 06, 2017 9:40 pm
Below function was showed in user_main.c. It generates error when build .bin file.
Question: 1) why we need this function?
2) what should I do to solve this issue?
uint32 ICACHE_FLASH_ATTR
user_rf_cal_sector_set(void)
uint32 rf_cal_sec = 0;
switch (size_map) {
rf_cal_sec = 128 - 5;
break;
rf_cal_sec = 256 - 5;
break;
rf_cal_sec = 512 - 5;
break;
rf_cal_sec = 1024 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
user_main.c: In function 'user_rf_cal_sector_set':
user_main.c:44:10: error: variable 'size_map' has initializer but incomplete type
user_main.c:44:25: error: storage size of 'size_map' isn't known
Re: build error using peripheral_test code
Postby Her Mary » Fri Apr 07, 2017 2:27 pm
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
 * FunctionName : user_rf_cal_sector_set
 * Description  : SDK just reversed 4 sectors, used for rf init data and paramters.
 *                We add this function to force users to set rf cal sector, since
 *                we don't know which sector is free in user's application.
 *                sector map for last several sectors : ABCCC
 *                A : rf cal
 *                B : rf init data
 *                C : sdk parameters
 * Parameters   : none
 * Returns      : rf cal sector
    switch (size_map) {
            break;
            break;
            break;
            break;
        default:
            rf_cal_sec = 0;
            break;
    return rf_cal_sec;
void ICACHE_FLASH_ATTR
user_rf_pre_init(void)
user_init(void)
Users browsing this forum: No registered users and 327 guests
