hello,
Is there any instructions for how to generate makefile?
generate makefile
Re: generate makefile
Postby mforcen » Fri Apr 07, 2017 6:37 pm
There are several examples of makefile within the net.
Found mine attached here:
It is intended to work with C and C++ sources (xtensa ports from jcmvbkbc at Github) using SDK.
AR = xtensa-lx106-elf-ar
CC = xtensa-lx106-elf-gcc
NM = xtensa-lx106-elf-nm
CPP = xtensa-lx106-elf-g++
LD = xtensa-lx106-elf-gcc
OBJCOPY = xtensa-lx106-elf-objcopy
OBJDUMP = xtensa-lx106-elf-objdump
CFLAGS += \
-Os \
-g \
-Wpointer-arith \
-Wundef \
-Werror \
-Wl,-EL \
-fno-inline-functions \
-nostdlib \
-mlongcalls \
-mtext-section-literals \
-D__ets__ \
-DICACHE_FLASH
CCFLAGS += \
-Os \
-g \
-Wpointer-arith \
-Wundef \
-Werror \
-Wl,-EL \
-nostdlib \
-mlongcalls \
-D__ets__ \
-DICACHE_FLASH \
-fno-rtti \
-fno-exceptions
INCLUDES += \
-I/opt/Espressif/ESP8266_NONOS_SDK/include \
-Iinclude \
-I.
LDDIR = -L/opt/Espressif/ESP8266_NONOS_SDK/lib/
LDFILE = -Teagle.app.v6.ld
LIBS = -lc -lmain -lgcc -lssl -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lwpa2 -lupgrade -lpwm -lsmartconfig -lwps -lcrypto -luart -lssl
SRC = $(wildcard *.cpp)
SRCC = $(wildcard *.c)
GDBSRC = $(wildcard gdb/*.c)
GDBASM = $(wildcard gdb/*.S)
OBJ = $(SRC:.cpp=.cpp.o)
OBJC =$(SRCC:.c=.o)
GDBASMOBJ = $(GDBASM:.S=.o)
GDBOBJ = $(GDBSRC:.c=.o)
LDFLAGS += \
-nostdlib \
-Wl,--no-check-sections \
-u call_user_start \
-Wl,-static \
$(LDDIR) \
$(LDFILE) \
-Wl,--start-group \
$(LIBS) \
app.a \
-Wl,--end-group
all: fichero.app.out
xtensa-lx106-elf-objdump --headers --section=.data --section=.rodata --section=.bss --section=.text --section=.irom0.text fichero.app.out
xtensa-lx106-elf-objcopy --only-section .text --output-target binary fichero.app.out eagle.app.v6.text.bin
xtensa-lx106-elf-objcopy --only-section .data --output-target binary fichero.app.out eagle.app.v6.data.bin
xtensa-lx106-elf-objcopy --only-section .rodata --output-target binary fichero.app.out eagle.app.v6.rodata.bin
xtensa-lx106-elf-objcopy --only-section .irom0.text --output-target binary fichero.app.out eagle.app.v6.irom0text.bin
python /opt/Espressif/ESP8266_NONOS_SDK/tools/gen_appbin.py fichero.app.out 0 0 0 0 6
fichero.app.out: compile
$(LD) $(LDFLAGS) -o $@
compile: app.a
app.a: $(OBJ) $(OBJC) $(GDBOBJ) $(GDBASMOBJ)
xtensa-lx106-elf-ar -cru app.a $^
$(OBJ): $(SRC)
$(CPP) $(CCFLAGS) $(INCLUDES) -c $(@:.o=) -o $@
$(OBJC): $(SRCC)
$(CC) $(CFLAGS) $(INCLUDES) -c $(@:.o=.c) -o $@
$(GDBOBJ): $(GDBSRC)
$(GDBASMOBJ): $(GDBASM)
$(CC) $(INCLUDES) -c $(@:.o=.S) -o $@
clean:
rm app.a *.o
rm eagle.app.v6.data.bin eagle.app.v6.irom0text.bin
rm eagle.app.v6.rodata.bin eagle.app.v6.text.bin fichero.app.out
rm eagle.app.flash.bin
rm gdb/*.o
flash:
esptool.py -p /dev/ttyUSB0 -b 115200 write_flash --flash_freq 40m --flash_mode qio --flash_size 32m 0x00000 eagle.app.flash.bin 0x10000 eagle.app.v6.irom0text.bin 0x3FC000 esp_init_data_default.bin 0x3FE000 blank.binIt is intended to work with C and C++ sources (xtensa ports from jcmvbkbc at Github) using SDK.
