can esp8266 sdk add keepalive get status interface?
Postby grantgao » Fri Apr 17, 2015 5:24 pm
i enabled the keepalive in my tcp socket,and it can send and receive keepalive packt will local server ,but i power off my local server suddenly to test what can the esp8266 note me in this case,and result is nothing ! so i am thinking ,why keepalive do nothing in this case? LWIP stack sure know what happened at this time ,can you add a callback interface into sdk for us ?
Re: can esp8266 sdk add keepalive get status interface?
Postby ESP_Faye » Fri Apr 17, 2015 5:33 pm
call espconn_regist_reconcb to register a reconnect callback, when TCP connection broke and retry fail, it goes into the reconnect callback.
Thanks for your interest in ESP8266 .
Postby grantgao » Fri Apr 17, 2015 5:54 pm
Espressif_Faye wrote:Hi,
i know what you said,and i also implemented the callback like this "espconn_regist_reconcb(user_contype.pCon, we_link_reconn_cb);"
it sure can reconnect when TCP connection broken. but i mean the otherwise,you can test as follow step:
1.boot esp8266 and wait it connect with local TCP server successful
2.plug out Ethernet wire(RJ45 on you PC)
now ,you can see esp8266 report nothing and won't enter "espconn_regist_reconcb" also
Postby grantgao » Fri Apr 17, 2015 5:59 pm
E文不好,还是用中文描述一遍吧,就是ESP8266------路由器------本地PC(TCP SERVER),其中路由器和PC是网线连接的,8266作为TCP client连上tcp server以后,如果此时拔掉PC端的网线,8266并无任何反应。如果有keepalive的话,底层的协议栈肯定知道这时候keepalive是收不到回应包的,从而可以通知用户程序,所以我才想到能否在sdk增加这样一个callback接口。
Postby ESP_Faye » Mon Apr 20, 2015 2:41 pm
您好,
麻烦调用 espconn_set_opt 设置 enable TCP keepalive
调用 espconn_regist_reconcb 注册 reconnect callback
当连接断开后,等待几分钟,底层 retry 失败后会进入 reconnect callback
Users browsing this forum: No registered users and 42 guests
