AP mode devices constant disconnecting / reconnecting
Anki
Postby Anki » Sat Apr 18, 2015 6:41 am
In AP mode looking at the debug output from the ESP8266, I see every 22.5 seconds
station: 84:3a:4b:d4:24:b0 leave, AID = 1
rm match
add 1
aid 1
station: 84:3a:4b:d4:24:b0 join, AID = 1
It takes about 2.5 seconds for the client to reconnect, so I am loosing about 2.5 seconds of data every 25 seconds. I have tried with several different devices connecting to the ESP8266 AP with similar results. What is going on here?
Anki
Re: AP mode devices constant disconnecting / reconnecting
Postby Anki » Wed Apr 22, 2015 5:06 am
This bug still happens when encryption is turned off. This is a serious bug, can we please have some attention on this?
Postby ESP_Faye » Wed Apr 22, 2015 9:51 am
sorry that we can't replicate your problem, can you offer more details about your test steps ? which SDK are you using ?
Anki
Postby Anki » Wed Apr 22, 2015 10:06 am
Hi Faye,
You can reproduce this problem using the same firmware I attached to this thread http://bbs.espressif.com/viewtopic.php?f=7&t=235&p=1457#p1457 compiled against the v1.0.1SDK (I'm sorry, I should have mentioned that in the original post)
Connect a Windows PC or Linux computer to the Espressif's wifi access point and watch the OS messages from UART1 and you will see the repeated join / leave messages.
Again, I am working to collect some wireshark captures and will attach when done.
Anki
Postby Anki » Wed Apr 22, 2015 10:22 am
Espressif_Faye,
Kindly let me know what email address I can send network captures to? I don't want to post directly on the forum. Should I send to feedback@espressif.com?
Thank you
Postby ESP_Faye » Wed Apr 22, 2015 10:38 am
Thanks for the reporting ,
with your test code ,we replicated your problem, we are working on it now.
Thanks again.
Anki
Postby Anki » Sat Apr 25, 2015 7:59 am
Please let me know if there is anything else I can do to help debug this issue. Have you found any insights into the issue? Thank you.
Anki
Postby Anki » Tue Apr 28, 2015 5:41 am
Doing more investigating on my own, this bug appears to be related to (or at least affected by) the beacon interval.
I tried increasing the beacon interval from default 100ms to 200ms and the problem occurred much more frequently. Then I tried decreasing the beacon interval to 33ms and now the problem seems to have gone away.
Postby ESP_Faye » Mon May 04, 2015 3:46 pm
sorry for the late reply, structure softap_config need to be initialized.
struct softap_config ap_config;
os_memset(&ap_config, 0, sizeof(ap_config));
or
   struct softap_config config;
   wifi_softap_get_config(&config); // Get config first.
you could refer to softAP config demo http://bbs.espressif.com/viewtopic.php?f=21&t=227
