udp callback problem.
nice72
Postby nice72 » Tue Apr 21, 2015 9:10 pm
We have developed a mesh system using esp8266.
At the time of all development is complete, We found a critical problem.
If ESP8266 received a retransmitted UDP packet, udp received callback function is called two times.
(*. received two udp packet's payload is exactly the same in the callback function )
There are several ways to solve the problem. But our application solution need a large memory pool.
I think that this problem should be solved in the wireless driver.
Did you already know this problem?
If you require more information to solve problems, I will immediately send you the information that you want.
Thanks,
Peter
Re: udp callback problem.
Postby ESP_Faye » Wed Apr 22, 2015 12:48 pm
"retransmitted UDP packet" you mean 802.11 retransmit ? or 802.3 retransmit ?
can you offer the capture packets logs for debugging ?
nice72
Postby nice72 » Thu Apr 23, 2015 8:17 am
Dear Sir,
All right. I will send you more details information to the Bug Bounty Program.
Peter
