2 new importants requirements in AT firmware
Postby phil31 » Thu Nov 13, 2014 9:07 pm
Hello
I would like to request some new and important features in the AT firmware :
- possibility to set up an STATIC IP (and all required others parameters, like gateway .. ).
the DHCP solution is not possible in every situation. some customer don't provide a DHCP server.
- an possibility to enable/disable an hardware handshake feature : RTS/CTS can be mapped on GPIO0/GPIO2 (which are almost available on all modules)
this is really important for some applications which can't parse quickly all data lines, from the ESP8266 chip. without such solution, I lose many message from the chip.
thanks, regards
thanks, regards
Re: 2 new importants requirements in AT firmware
Postby phil31 » Sat Nov 29, 2014 8:56 pm
Hi Espressif team,
please, do you plan to add hardware Handshake feature soon, in the official AT commands firmware ?
using GPIO 13 & 15 as RTS / CTS pins ?
thanks
Phil
thanks
Phil
Postby phil31 » Tue Dec 02, 2014 4:57 pm
please may i expect an answer ?
Is it that I'm the only one who need this feature?
i don't expect so !?? all HOST cpu don't have plenty of SRAM to manage a big buffer (by example to store the full HTML header when a socket is open) before parse all the lines !
so without hardware handshake, we can't use this famous chip to play a web server role...
thanks, regards
thanks, regards
Espressif_Kelly
Postby Espressif_Kelly » Mon Dec 15, 2014 3:20 pm
Dear Sir,
The current SDK supports hardware flow control by default. Please make a try.
Only MTCK(GPIO13) can be reused as UART0 CTS and MTDO(GPIO15) can be reused as UART0 RTS. CTS/RTS can not be swapped to GPIO0/GPIO2.
Please be noted.
Please be noted.
Postby bjpirt » Tue Mar 24, 2015 1:10 am
Following up on the first part of the original question; I too would like to be able to disable the DHCP client on the STATION interface and supply a static IP address. It doesn't look like this information gets saved anywhere because when I call wifi_station_dhcpc_stop(), when I restart the DHCP client is back in place.
It would be great if wifi_station_dhcpc_stop() was made persistent and that the ip_info struct was also stored in persistent memory so that it is possible to set up a static IP address
What do the Espressif folks think about this? Am I understanding things correctly?
Cheers,
Ben
Cheers,
Ben
