+IPD difference between UDP & TCP
trickedj
Postby trickedj » Mon Apr 27, 2015 12:15 am
I have noticed in AT v23 that the +IPD responses are different between UDP & TCP.
In UDP the raw data is followed by an "OK" in TCP it is not. I've just updated from AT v20 and in that version both TCP & UDP issued an OK after the raw data. There was some discussion here viewtopic.php?f=16&t=221 about the removal of the (unneccessary) ok on TCP, but it appears to have been overlooked on UDP. It would be best for them to be both the same.
D Tricker
An example follows:
AT+GMR
AT version:0.23.0.0(Apr 24 2015 21:11:01)
SDK version:1.0.1
compile time:Apr 24 2015 21:19:31
AT+CIFSR
+CIFSR:STAIP,"192.168.1.84"
+CIFSR:STAMAC,"18:fe:34:9c:65:bd"
AT+CIPSTART="UDP","192.168.1.71",100,100,0
0,CONNECT
+IPD,8:incoming
OK <<<<<<<<<<<<<< Extra LF OK LF on UDP packet containing "incoming"
AT+CIPMUX=1
AT+CIPSERVER=1,100
0,CONNECT
+IPD,0,8:incoming0,CLOSED <<<<<<<<<<<<<< Nothing extra on TCP
0,CONNECT
+IPD,0,8:incoming1,CONNECT
+IPD,1,8:incoming0,CLOSED
0,CONNECT
+IPD,0,8:incoming1,CLOSED
0,CLOSED
Re: +IPD difference between UDP & TCP
Postby ESP_Faye » Mon Apr 27, 2015 10:56 am
Thanks for your valuable advice,we will revise UDP to be same as TCP .
