memory leak in secure connection
Postby ememberus » Thu May 04, 2017 1:14 am
espconn_secure_connect() is used instead of espconn_connect().
The issue appears only when RF signal is weak or disrupted
due to RF interference, obstacles between ESP8266 and AP etc,
and client connection is temporarily lost.
I attach 2 screenshots of ThingSpeak plots of "free heap" memory traces:
1. heap memory after RF signal is disrupted several times when using a secure connection
2. heap memory after RF signal is similarly disrupted when using unsecure connection
Re: memory leak in secure connection
Postby Her Mary » Thu May 04, 2017 5:08 pm
Postby ememberus » Wed May 10, 2017 9:10 am
I had to modify your code to simulate my conditions, but so far it did not produce anything conclusive.
Results seem very strange, though. First connection opens quickly, but all others that follow are very
unstable, crashing CPU from time to time. I cannot run my test long enough to say there is no leak
or it is there.
Please, take a look at my test code and tell whether you see anything wrong.
FYI:
- my test runs HTTP client periodically, opening a connection and closing it after each send/receive exchange
- in order to weaken RF signal and cause periodic disconnects, I put esp8266 into antistatic bag
- random RF disconnects are crucial, if RF signal is strong then memory leak (and lately crashes) never occur
// SDK v2.0.0, non-RTOS
#include "mem.h"
#include <c_types.h> // uint8 etc
#include <ip_addr.h> // ip_addr_t
#include <espconn.h> // espconn_gethostbyname() etc
#include <os_type.h> // os_timer_t
#include <osapi.h> // os_printf()
#include <user_interface.h>
#include "user_config.h"
#define DNS_ENABLE
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
//#define NET_DOMAIN "iot.espressif.cn"
#define NET_DOMAIN "api.thingspeak.com"
#ifndef SNTP_START
#define SNTP_START()
#endif
#ifndef DEBUG_REPORT
#define DEBUG_REPORT(...)
#endif
void *pvPortMalloc(size_t xWantedSize, const char *file, int line);
void *pvPortZalloc(size_t, const char *file, int line);
void *pvPortRealloc(void *, size_t xWantedSize, const char *file, int line);
void vPortFree(void *ptr, const char *file, int line);
void *vPortMalloc(size_t xWantedSize, const char *file, int line);
void pvPortFree(void *ptr, const char *file, int line);
int os_printf_plus(const char *format, ...) __attribute__ ((format (printf, 1, 2)));
int os_snprintf(char *str, size_t size, const char *format, ...) __attribute__ ((format (printf, 3, 4)));
size_t ets_strlen(const char *s);
int ets_sprintf(char *str, const char *format, ...) __attribute__ ((format (printf, 2, 3)));
void *ets_memcpy(void *dest, const void *src, size_t n);
void ets_timer_arm_new(ETSTimer *a, int b, int c, int isMstimer);
void ets_timer_disarm(ETSTimer *a);
void ets_timer_setfn(ETSTimer *t, ETSTimerFunc *fn, void *parg);
LOCAL void user_check_ip (void * args);
char http_buf[20000];
bool tcp_connected = false;
#define packet_size (2 * 1024)
LOCAL os_timer_t test_timer;
LOCAL os_timer_t send_timer;
LOCAL struct _esp_tcp user_tcp;
LOCAL struct espconn user_tcp_conn = { ESPCONN_TCP, ESPCONN_NONE, { &user_tcp } };
LOCAL ip_addr_t tcp_server_ip = { 0 };
* FunctionName : user_tcp_connect_cb
* Description : A new incoming tcp connection has been connected.
* Parameters : arg -- Additional argument to pass to the callback function
* Returns : none
LOCAL void ICACHE_FLASH_ATTR
user_tcp_connect_cb (void *arg)
// struct espconn *pespconn = arg;
os_timer_disarm(&test_timer);
os_printf("user_tcp_connect_cb: connected !!!\r\n");
tcp_connected = true;
DEBUG_REPORT(CONNECT);
* FunctionName : user_tcp_recon_cb
* Description : reconnect callback, error occured in TCP connection.
* Returns : none
user_tcp_recon_cb (void *arg, sint8 err)
// if connection err, then user can try to reconnect here.
struct espconn * pespconn = (struct espconn *) arg;
DEBUG_REPORT(RECONNECT);
switch (err)
case ESPCONN_OK:
os_printf ("user_tcp_recon_cb: TCP connected\r\n");
break;
default:
os_printf("user_tcp_recon_cb: TCP connect error %d, reconnecting... !!!\r\n",err);
espconn_secure_connect(pespconn); // tcp SSL connect
* FunctionName : user_tcp_discon_cb
* Description : disconnect callback.
* Returns : none
user_tcp_discon_cb (void *arg)
os_printf("user_tcp_discon_cb: TCP disconnected !!!\r\n");
// espconn_secure_disconnect (arg);
// espconn_delete (arg);
DEBUG_REPORT(DISCONNECT);
* FunctionName : user_tcp_sent_cb
* Description : data sent callback.
* Returns : none
user_tcp_sent_cb (void *arg)
os_printf("user_tcp_sent_cb: TCP data sent !!!\r\n");
* FunctionName : user_tcp_recv_cb
* Description : receive callback.
* Returns : none
user_tcp_recv_cb (void *arg, char *pusrdata, unsigned short length)
// os_printf("user_tcp_recv_cb: data received !!!\r\n%s\r\n", pusrdata);
os_printf("user_tcp_recv_cb: TCP %d bytes received !!!\r\n", length);
* FunctionName : user_esp_platform_sent
* Description : Processing the application data and sending it to the host
* Parameters : pespconn -- the espconn used to connection with the host
* Returns : none
user_send (void * args)
static int count = 0;
struct espconn * pespconn = (struct espconn *) args;
count++;
if (tcp_connected)
unsigned free_heap_size = system_get_free_heap_size ();
os_printf ("free heap = %d\r\n", free_heap_size);
os_sprintf(http_buf,
"GET /update?api_key=%s&field1=%d&field2=%d HTTP/1.1\r\n"
"Host: %s:%d\r\n"
"Connection: close\r\n"
"User-Agent: ESP8266\r\n"
"\r\n",
API_KEY, count, free_heap_size, "api.thingspeak.com", 443);
espconn_secure_sent (pespconn, (uint8 *) http_buf, os_strlen(http_buf));
else
os_printf ("user_sent_data: TCP not connected\r\n");
os_timer_setfn(&test_timer, user_check_ip, NULL);
os_timer_arm(&test_timer, 100, 0);
#ifdef DNS_ENABLE
* FunctionName : user_dns_found
* Description : dns found callback
* Parameters : name -- pointer to the name that was looked up.
* ipaddr -- pointer to an ip_addr_t containing the IP address of
* the hostname, or NULL if the name could not be found (or on any
* other error).
* callback_arg -- a user-specified callback argument passed to
* dns_gethostbyname
* Returns : none
user_dns_found_cb(const char *name, ip_addr_t *ipaddr, void *arg)
struct espconn *pespconn = (struct espconn *)arg;
if (ipaddr == NULL)
os_printf("user_dns_found: invalid pointer NULL\r\n");
return;
os_printf("user_dns_found: %d.%d.%d.%d\r\n",
*((uint8 *)&ipaddr->addr), *((uint8 *)&ipaddr->addr + 1),
*((uint8 *)&ipaddr->addr + 2), *((uint8 *)&ipaddr->addr + 3));
if (tcp_server_ip.addr == 0) // first time initializing connection?
if (ipaddr->addr != 0)
// dns succeed, create tcp connection
if (!tcp_connected)
tcp_server_ip.addr = ipaddr->addr;
os_memcpy(pespconn->proto.tcp->remote_ip, &ipaddr->addr, 4); // remote ip of tcp server which get by dns
pespconn->proto.tcp->remote_port = 443; // remote SSL port of tcp server
pespconn->proto.tcp->local_port = espconn_port(); //local port of ESP8266
espconn_regist_connectcb(pespconn, user_tcp_connect_cb); // register connect callback
espconn_regist_reconcb(pespconn, user_tcp_recon_cb); // register reconnect callback as error handler
espconn_regist_disconcb(pespconn, user_tcp_discon_cb); // register disconnect callback here, because that SSL handshake may fail.
espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
espconn_regist_sentcb(pespconn, user_tcp_sent_cb);
espconn_secure_set_size(ESPCONN_CLIENT,5120); // set SSL buffer size, if your SSL packet larger than 2048 bytes
else
os_printf("user_dns_found: TCP already connected\r\n");
else
os_printf("user_dns_found: unknown dns error\r\n");
else // remote IP resolved
if (!tcp_connected)
os_timer_arm(&test_timer, 1000, 0); // resume dns check
* FunctionName : user_esp_platform_dns_check_cb
* Description : 1s time callback to check dns found
* Returns : none
user_dns_check_cb (void *arg)
if (tcp_server_ip.addr == 0) // remote IP not resolved?
ip_addr_t remote_ip = { 0 };
sint8 res = espconn_gethostbyname (pespconn, NET_DOMAIN, &remote_ip, user_dns_found_cb);
switch (res)
case ESPCONN_OK:
os_printf ("DNS request succeed\r\n");
break;
case ESPCONN_INPROGRESS:
os_printf ("DNS request in progress...\r\n");
break; // OK
default:
os_printf ("DNS request failed %d\r\n", res);
os_timer_arm(&test_timer, 1000, 0); // resume IP check
if (!tcp_connected)
os_printf ("user_dns_check_cb: IP resolved, connecting...\r\n");
os_timer_arm(&test_timer, 10000, 0); // resume IP check
#endif
* FunctionName : user_check_ip
* Description : check whether get ip addr or not
* Parameters : none
* Returns : none
user_check_ip (void * dummy)
struct ip_info ipconfig;
//get ip info of ESP8266 station
if (wifi_station_get_connect_status() == STATION_GOT_IP && ipconfig.ip.addr != 0)
os_printf("user_check_ip: WiFi connected !!!\r\n");
// os_timer_disarm (&test_timer);
// os_timer_setfn (&test_timer, user_dns_check_cb, &user_tcp_conn);
user_dns_check_cb (&user_tcp_conn);
else
if ((wifi_station_get_connect_status() == STATION_WRONG_PASSWORD ||
wifi_station_get_connect_status() == STATION_NO_AP_FOUND ||
wifi_station_get_connect_status() == STATION_CONNECT_FAIL))
os_printf("user_check_ip: WiFi connect fail !!!\r\n");
else
os_printf("user_check_ip: WiFi not connected !!!\r\n");
// re-arm timer to check ip
* FunctionName : user_set_station_config
* Description : set the router info which ESP8266 station will connect to
* Parameters : none
* Returns : none
user_set_station_config ()
// Wifi configuration
char ssid[32] = SSID;
char password[64] = PASSWORD;
// need not mac address
stationConf.bssid_set = 0;
// set ap settings
// set a timer to check whether got ip from router succeed or not.
* FunctionName : user_init
* Parameters : none
* Returns : none
void user_init ()
io_init (); // UART0 etc
// set station mode
// ESP8266 connect to AP
user_set_station_config();
SNTP_START();
os_timer_disarm(&send_timer);
os_timer_setfn(&send_timer, user_send, &user_tcp_conn);
os_timer_arm(&send_timer, 20000, true);
Postby ememberus » Fri May 12, 2017 1:14 am
While dns_check_cb reads WiFi status as "connected",
TCP client is repeatedly unable to connect and free
heap memory slowly goes down.
Once rebooted, the board immediately connects
to AP and to remote server. Sometimes this releases
allocated heap memory, but sometimes not.
ip:10.0.0.43,mask:255.255.255.0,gw:10.0.0.1
dns_check_cb: DNS request in progress...
dns_resolved_cb: 52.1.229.129
please start sntp first !
client handshake start.
client handshake ok!
pm open,type:2 0
user_send: free heap = 16904
tcp_recv_cb: TCP 638 bytes received !!!
client's data invalid protocol
Error: SSL error 3
2017-05-11 16:43:42 GMT
tcp_disconnect_cb: TCP disconnected !!!
dns_check_cb: remote IP resolved, connecting...
2017-05-11 16:44:08 GMT
tcp_reconnect_cb: TCP connect error -11, reconnecting... !!!
2017-05-11 16:44:13 GMT
2017-05-11 16:44:14 GMT
Error: SSL error 3
2017-05-11 16:45:13 GMT
2017-05-11 16:45:22 GMT
user_send: free heap = 16704
Error: SSL error 3
2017-05-11 16:45:42 GMT
2017-05-11 16:46:02 GMT
Please, note another issue with connect/disconnect events.
Last TCP disconnect comes out of nowhere -
there is no prior matching "connect" event (
Overall, the pattern may vary slightly in details, but mostly
keep repeating itself on my board.
Postby ememberus » Fri May 12, 2017 1:19 am
a successful connect may sometimes release allocated heap memory.
A CPU reboot will obviously clear all prior heap allocations.
Postby pratik » Sun May 28, 2017 10:26 pm
Dashaduamp
Postby Dashaduamp » Wed Jun 21, 2017 10:38 am
A leak is memory usage that continues to grow and never stops.
19MB is operating within its proper bounderies.
v4.9 is no longer available...
Postby ememberus » Wed Jun 21, 2017 10:06 pm
I also not sure how 19Mb or v4.9 matters.
Care to clarify?
You may also want to look into this recent thread:
viewtopic.php?f=66&t=4701
Alltogether, these findings point to possible memory leak(s) in SDK TCP stack.
