sorry,
have found the uart.h in examples in IoT_Demo Folder
-> include/driver
all ok.
my mistake,i have wounder me, why the uart.h ist not in AT demo
best wishes
rudi
its time for holiday
hi
for longer time i do not need uart code's but now, i need this again with newer sdk, and i have seen, that uart.h is not longer availabel / hidden ..
is there a possible choice for API or a other point to add a custom baudrate, because AT is still not longer open source and uart.h is gone
example earlier sdk version was this possible like this way:
add a custom baudrate in uart.h
typedef enum {
BIT_RATE_9600 = 9600,
// example Custom
BIT_RATE_80000 = 80000, // Only example !! no really functionally bautrate..
BIT_RATE_921600 = 921600
} UartBautRate;
then in user init
// This changed the Bautrate to custom
uart_init(BIT_RATE_80000, BIT_RATE_115200);
how we can do this now in actually sdk?
thank you!
best wishes
rudi
// edit
In AT Command Construction there is a AT Command possible:
AT+UART_DEF=80000,8,1,0,0
how i can do this in api or user code from scratch.
thank you!
