NodeMcu - A lua based firmware for esp8266
zeroday
Postby zeroday » Fri Nov 14, 2014 8:30 pm
Hi, all
Glad to release a firmware that is powered by lua.
https://github.com/nodemcu/nodemcu-firmware
This firmware act like a lua interpreter inside esp8266,
you can type lua chunk from serial port, and do what ever you like.
here are some examples:
Config wifi
    print(wifi.sta.getip())
    --0.0.0.0
    wifi.setmode(wifi.STATION)
    wifi.sta.config("SSID","password")
    --192.168.18.110
Manipulate hardware like a arduino
    pin = 1
    gpio.mode(pin,gpio.OUTPUT)
    gpio.write(pin,gpio.HIGH)
    print(gpio.read(pin))
Write network application in nodejs style
    -- A simple http client
    conn=net.createConnection(net.TCP, false)
    conn:on("receive", function(conn, payload) print(c) end )
    conn:connect(80,"115.239.210.27")
    conn:send("GET / HTTP/1.1\r\nHost: www.baidu.com\r\n"
        .."Connection: keep-alive\r\nAccept: */*\r\n\r\n")
Or a simple http server
    -- A simple http server
    srv=net.createServer(net.TCP)
    srv:listen(80,function(conn)
      conn:on("receive",function(conn,payload)
        print(payload)
        conn:send("<h1> Hello, NodeMcu.</h1>")
      end)
    end)
Play with LED
  function led(r,g,b)
    pwm.setduty(0,r)
    pwm.setduty(1,g)
    pwm.setduty(2,b)
  end
  pwm.setup(0,500,50)
  pwm.setup(1,500,50)
  pwm.setup(2,500,50)
  pwm.start(0)
  pwm.start(1)
  pwm.start(2)
  led(50,0,0) -- red
  led(0,0,50) -- blue
If you want to run something when system started
  --init.lua will be excuted
  file.open("init.lua","w")
  file.writeline([[print("Hello, do this at the beginning.")]])
  file.close()
  node.restart()  -- this will restart the module.
Hope you guys like it.
costaud
Re: NodeMcu - A lua based firmware for esp8266
Postby costaud » Sat Nov 15, 2014 10:53 pm
Excellent!!
Looking forward to the source code!
Squonk
Postby Squonk » Sun Nov 16, 2014 5:20 pm
costaud wrote:Excellent!!
This won't happen "soon" :cry:
User avatar
rudi
Postby rudi » Tue Nov 18, 2014 6:32 pm
why you think this not happen soon ?
btw
lua, which version * you take zeroday * ..
actual release is 5.2.3 ? , there are more developer version's
test1, test2, test3.. ., alpha, work, beta ;-) ...
http://www.lua.org/work/
http://www.lua.org/versions.html
http://www.lua.org/ftp/
because i work on 5.2.3
http://www.lua.org/ftp/lua-5.2.3.tar.gz
and esp8266 too .. ;-)
is this oK for the grit fw zeroday?
best wishes
rudi ;-)
edit: declare lua version *
問候飛出去的朋友遍全球魯迪
alonewolfx2
Postby alonewolfx2 » Wed Dec 31, 2014 8:00 pm
It's open-source now. Here is github link https://github.com/nodemcu/nodemcu-firmware
