At command problem
User avatar
vishnu046
At command problem
Postby vishnu046 » Thu May 21, 2015 1:36 pm
hi while checking AT mode in 8266....
in first bootup.....
i entered AT it working good
if once again i removed the power and kept it back then AT command is not working...?
boot.docx
(109.3 KiB) Downloaded 495 times
Vishnu
doughboy
Re: At command problem
Postby doughboy » Thu May 21, 2015 4:32 pm
are you using the latest firmware on a 512kb flash module?
if so, that will happen.
try to upload this firmware
viewtopic.php?f=16&t=400&start=10#p1662
User avatar
vishnu046
Postby vishnu046 » Thu May 21, 2015 6:52 pm
Hi its not 512 kB I am using 4Mb flash
Vishnu
Postby ESP_Faye » Tue May 26, 2015 4:08 pm
Please try the latest flash download tool_v1.2 http://bbs.espressif.com/viewtopic.php?f=5&t=433
Choose flash size as 1024KB, according to http://bbs.espressif.com/viewtopic.php?f=10&t=305
blank.bin burns into flash 0xFE000
Use the latest boot.bin, such as boot_v1.3+
If your problem is still unsolved, please offer the capture picture of your flash download tool while downloading and the UART output log when running.
