I reported a bug on the 18th & was asked to test some different code to isolate the problem .
I ran the code & reported back on the 19th .
I've sent 3 emails now & had no response ?
Regards
Barry
** Update **
Got an Email with a response .
Thank you .
BBP#102
Re: BBP#102
Postby BarryP » Wed May 27, 2015 7:34 am
The timer Problem has become worse with SDKv1.1.0
My original problem was the us Timer was stopping and restarting with long time periods between each stop or start .
Now the problem is resulting in wdt resets .
I have done further tests on the problem using my scope.
I toggle a pin on each timer event.
I have been triggering on pulses less than 10uS with the uS Timer setup at 100uS .
This is the results .
1/ 100uS pulses stop for 5.4 milli Secs
2/ 200uS of 4uS pulses
3/ 60uS of mark or space
4/ normal 100uS pulses resume
Here is the code .
Regards
Barry
Here is the code .
* user_config.h
* Created on: 18/05/2015
* Author: Barry
#ifndef USER_USER_CONFIG_H_
#define USER_USER_CONFIG_H_
#define USE_US_TIMER
#endif /* USER_USER_CONFIG_H_ */
* user_main.c
* Author: Barry
#include "osapi.h"
#include "c_types.h"
#include "ets_sys.h"
#include "gpio.h"
#include "user_config.h"
#include "user_interface.h"
static bool inpinval = true;
static bool toggle = true;
static volatile os_timer_t sample_window_timer;
void user_rf_pre_init(void)
void sample_window_timer_cb(void *arg){
inpinval = GPIO_INPUT_GET(GPIO_ID_PIN(5)); //5
toggle = !toggle;
GPIO_OUTPUT_SET(GPIO_ID_PIN(15), toggle);//15
//Init function
void user_init()
system_timer_reinit();
gpio_init();
// GPIO15 As Output
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U,FUNC_GPIO15);
GPIO_OUTPUT_SET(GPIO_ID_PIN(15), 1);
// GPIO5 as Input
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO5_U, FUNC_GPIO5);
os_timer_disarm(&sample_window_timer);
os_timer_setfn(&sample_window_timer, (os_timer_func_t *)sample_window_timer_cb, NULL);
#ifdef USE_US_TIMER
os_timer_arm_us(&sample_window_timer, 100, 1);
#else
os_timer_arm(&sample_window_timer, 1, 1);
#endif
Regards
Barry
