ESP8266-12F 烧录后一直重启的问题
pigeon0411
Postby pigeon0411 » Sat May 27, 2017 11:26 am
各位好,
我使用nodemcu:esp8266-12f 的板子,用官方最新的SDK 编译了一个简单的helloword程序,用官方的FLASH烧录工具,一直烧录不进去。
使用安信可的 ESP8266Flasher 很容易升级成功,但是成功后,一直反复重启。
打印信息:
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
OS SDK ver: 1.5.0-dev(7f7a714) compiled @ May 12 2017 18:16:00
rf_cal[0] !=0x05,is 0xFF
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
l
请帮忙看看是什么原因引起的?
波特率是74880
打印信息:
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
l
请帮忙看看是什么原因引起的?
波特率是74880
pigeon0411
Re: ESP8266-12F 烧录后一直重启的问题
Postby pigeon0411 » Wed May 31, 2017 9:14 am
编译没有问题,烧录也是按着这个文档配置的。
唯一有一点不同的是:
文档上FLASH大小 4096 (1024+1024)
而模块打印信息的FLASH大小是 4096(256+256),这个有什么不同呢? 文档上并没有关于这个的说明。
唯一有一点不同的是:
pigeon0411
Her Majesty wrote:编译烧录有问题,可以参考 ESP8266 入门指南
唯一有一点不同的是:
Users browsing this forum: No registered users and 308 guests
