Inconsistent sleeping with SDK 2.1.0 uint64_t sleep times
torntrousers
Postby torntrousers » Sat May 27, 2017 4:56 pm
For example, calling system_deep_sleep with these works as expected:
uint64_t sleepTime = 10000000; // WORKS: 10 seconds
uint64_t sleepTime = 7200000000; // WORKS: 2 hours
uint64_t sleepTime = 9000000000; // WORKS: 2.5 hours
uint64_t sleepTime = 86400000000; // WORKS: 24 hours
But calling system_deep_sleep with values like these doesn't work and the ESP8266 wakes up almost immediately:
uint64_t sleepTime = 21600000000; // FAILS: 6 hours
uint64_t sleepTime = 74049000000; // FAILS: bit over 20 hours
In all cases system_deep_sleep is returning true, and the ESP8266 wakes up with rst cause:2, boot mode:(3,6).
What could be wrong, is this a bug?
Re: Inconsistent sleeping with SDK 2.1.0 uint64_t sleep times
Postby pratik » Sun May 28, 2017 9:41 pm
Ensure that this has nothing to do with loose connections, if you are working on a prototype. Meanwhile I will let you know if I can reproduce this exact problem.
torntrousers
Postby torntrousers » Tue May 30, 2017 4:35 pm
Postby Her Mary » Wed May 31, 2017 1:57 pm
It is mentioned in the non OS API guide.
torntrousers
Postby torntrousers » Wed May 31, 2017 4:08 pm
The theoretical maximum value of time_in_us can be calculated by formula:
(time_in_us / cali) << 12 = 2^32 - 1
• cali = system_rtc_clock_cali_proc(), the cali is the RTC clock period (in us)
In system_rtc_clock_cali_proc in 3.3.22 it says:
RTC clock period (in us); bit11 ~ bit0 are decimal.
Example os_printf("clk cal : %d \r\n",system_rtc_clock_cali_proc()>>12);
When I try that printf on an ESP8266 it outputs "clk cal : 6"
So (time_in_us / cali) << 12 = 2^32 - 1
So time_in-us = ( (2^32 - 1) >> 12 ) * 6
= 6291450
Which is just 6 seconds! Clearly wrong as it sleeps for longer than that fine. Can anyone do the maths better?
Postby Her Mary » Thu Jun 01, 2017 11:26 am
It is "cali = system_rtc_clock_cali_proc()", not "cali = system_rtc_clock_cali_proc()>>12".
torntrousers
Postby torntrousers » Thu Jun 01, 2017 12:51 pm
Postby ESP_Faye » Mon Jun 19, 2017 10:04 am
The deep sleep 0 issue has been solved, please have a try with the latest SDK. https://github.com/espressif/ESP8266_NONOS_SDK
Users browsing this forum: No registered users and 301 guests
