A first order sigma-delta signal from io pin source
costaud
Postby costaud » Tue Nov 18, 2014 2:59 am
* MODULEName : set_sigma MODULE
A first order sigma-delta is just like a pwm signal.
EACH PIN CAN CONNET TO A SIGMA-DELTA , ALL PINS SHEARS THE SAME SIGMA-DELTA SOURCE.
THE TARGET DUTY AND FREQUENCY CAN BE MODIFIED VIA THE REG ADDR GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_SIGMA_DELTA_NUM))
THE TARGET FREQUENCY IS DEFINED AS:
FREQ = 80,000,000/prescale * target /256 HZ, 0<target<128
FREQ = 80,000,000/prescale * (256-target) /256 HZ, 128<target<256
target: duty ,0-255
prescale: clk_div,0-255
so the target and prescale will both affect the freq.
YOU CAN DO THE TEST LIKE THIS:
1. INIT : sigma_delta_setup(PERIPHS_IO_MUX_MTDI_U,12,FUNC_GPIO12);
2. USE 312K: set_sigma_duty_312KHz(2);
OR 2. SET VAL: set_sigma_target(uint8 target) AND set_sigma_prescale
3. DE-INIT AND DISABLE: sigma_delta_close(uint32 GPIO_NUM), eg.sigma_delta_close(2)
THE TARGET DUTY AND FREQUENCY CAN BE MODIFIED VIA THE REG ADDR GPIO_SIGMA_DELTA
target: duty ,0-255
3. DEINIT AND DISABLE: sigma_delta_close(uint32 GPIO_NUM), eg.sigma_delta_close(2)
#include "osapi.h"
#include "c_types.h"
#include "ets_sys.h"
#include "eagle_soc.h"
#include "gpio.h"
#define GPIO_PIN_ADDR(i) (GPIO_PIN0_ADDRESS + i*4)
#define GPIO_SIGMA_DELTA      0x60000368  //defined in gpio register.xls
#define GPIO_SIGMA_DELTA_SETTING_MASK  (0x00000001ff)
#define GPIO_SIGMA_DELTA_ENABLE  1
#define GPIO_SIGMA_DELTA_DISABLE   (~GPIO_SIGMA_DELTA_ENABLE)
#define GPIO_SIGMA_DELTA_MSB                     16
#define GPIO_SIGMA_DELTA_LSB                      16
#define GPIO_SIGMA_DELTA_MASK                  (0x00000001<<GPIO_SIGMA_DELTA_LSB)
#define GPIO_SIGMA_DELTA_GET(x)                 (((x) & GPIO_SIGMA_DELTA_MASK) >> GPIO_SIGMA_DELTA_LSB)
#define GPIO_SIGMA_DELTA_SET(x)                  (((x) << GPIO_SIGMA_DELTA_LSB) & GPIO_SIGMA_DELTA_MASK)
#define GPIO_SIGMA_DELTA_TARGET_MSB  7
#define GPIO_SIGMA_DELTA_TARGET_LSB  0
#define GPIO_SIGMA_DELTA_TARGET_MASK                  (0x000000FF<<GPIO_SIGMA_DELTA_TARGET_LSB)
#define GPIO_SIGMA_DELTA_TARGET_GET(x)                 (((x) & GPIO_SIGMA_DELTA_TARGET_MASK) >> GPIO_SIGMA_DELTA_TARGET_LSB)
#define GPIO_SIGMA_DELTA_TARGET_SET(x)                  (((x) << GPIO_SIGMA_DELTA_TARGET_LSB) & GPIO_SIGMA_DELTA_TARGET_MASK)
#define GPIO_SIGMA_DELTA_PRESCALE_MSB  15
#define GPIO_SIGMA_DELTA_PRESCALE_LSB  8
#define GPIO_SIGMA_DELTA_PRESCALE_MASK  (0x000000FF<<GPIO_SIGMA_DELTA_PRESCALE_LSB)
#define GPIO_SIGMA_DELTA_PRESCALE_GET(x)                 (((x) & GPIO_SIGMA_DELTA_PRESCALE_MASK) >> GPIO_SIGMA_DELTA_PRESCALE_LSB)
#define GPIO_SIGMA_DELTA_PRESCALE_SET(x)                  (((x) << GPIO_SIGMA_DELTA_PRESCALE_LSB) & GPIO_SIGMA_DELTA_PRESCALE_MASK)
 * FunctionName : sigma_delta_setup
 * Description  : Init Pin Config for Sigma_delta , change pin source to sigma-delta
 * Parameters   : uint32 GPIO_MUX, GPIO MUX REG ,DEFINED IN EAGLE_SOC.H, e.g.: PERIPHS_IO_MUX_MTCK_U
        uint32 GPIO_NUM, GPIO NUM ACCORDING TO THE MUX NUM , e.g.: 13 for MTCK
        uint32 GPIO_FUNC, GPIO PIN FUNC , DEFINED IN EAGLE_SOC.H , e.g.: FUNC_GPIO13
 * Returns      : none
void ICACHE_FLASH_ATTR
sigma_delta_setup(uint32 GPIO_MUX,uint32 GPIO_NUM,uint32 GPIO_FUNC)
    //STEP 1: SIGMA-DELTA CONFIG;REG SETUP
    GPIO_REG_WRITE(GPIO_SIGMA_DELTA,
                                                        (GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_SIGMA_DELTA_NUM))) &(~GPIO_SIGMA_DELTA_SETTING_MASK))|
                                                          GPIO_SIGMA_DELTA_SET(GPIO_SIGMA_DELTA_ENABLE)|
                                                          GPIO_SIGMA_DELTA_TARGET_SET(0x00)|
                                                          GPIO_SIGMA_DELTA_PRESCALE_SET(0x00) );
    //STEP 2: PIN FUNC CONFIG :SET PIN TO GPIO MODE AND ENABLE OUTPUT
    PIN_FUNC_SELECT(GPIO_MUX, GPIO_FUNC);
    gpio_output_set(0,0,0x1<<GPIO_NUM,0);
    //STEP 3: CONNECT SIGNAL TO GPIO PAD
    GPIO_REG_WRITE(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_NUM)),
                                                            GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_NUM)))|
                                                            GPIO_PIN_SOURCE_SET(  SIGMA_AS_PIN_SOURCE )                     );
    //ets_printf("test reg gpio mtdi : 0x%08x \n",GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_NUM))));
 * FunctionName : sigma_delta_close
 * Description  : DEinit Pin ,from Sigma_delta mode to GPIO input mode
 * Parameters   : uint32 GPIO_NUM, GPIO NUM ACCORDING TO THE MUX NUM , e.g.: 13 for MTCK
 * Returns      : none
    //STEP 1: SIGMA-DELTA DEINIT
                                                          GPIO_SIGMA_DELTA_SET(GPIO_SIGMA_DELTA_DISABLE)|
    //ets_printf("test reg gpio sigma : 0x%08x \n",GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_SIGMA_DELTA_NUM))));
    //STEP 2: GPIO OUTPUT DISABLE
    gpio_output_set(0,0,0,0x1<<GPIO_NUM);
    //STEP 3: CONNECT GPIO TO PIN PAD
                                                            GPIO_PIN_SOURCE_SET(  GPIO_AS_PIN_SOURCE )                     );
 * FunctionName : set_sigma_target
 * Description  : SET TARGET DUTY FOR SIGMA-DELTA
 * Parameters   : uint8 target, DUTY NUM , 1BYTE , DUTY RANGE : 0-255
 * Returns      : none
    //set sigma signal duty target
                                                        (GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_SIGMA_DELTA_NUM))) &(~GPIO_SIGMA_DELTA_TARGET_MASK))|
                                                          GPIO_SIGMA_DELTA_TARGET_SET(target));
 * FunctionName : set_sigma_prescale
 * Description  : SET SIGMA-DELTA SIGNAL CLK PRESCALE(CLE_DIV)
 * Parameters   : uint8 prescale, CLK_DIV , 0-255
 * Returns      : none
    set_sigma_prescale(uint8 prescale)
    //set sigma signal clk prescale(clk div)
                                                        (GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_SIGMA_DELTA_NUM))) &(~GPIO_SIGMA_DELTA_PRESCALE_MASK))|
                                                          GPIO_SIGMA_DELTA_PRESCALE_SET(prescale) );
 * FunctionName : set_sigma_duty_312KHz
 * Description  : 312K CONFIG EXAMPLE
 * Parameters   : uint8 duty, TARGET DUTY FOR 312K,  0-255
 * Returns      : none
    set_sigma_duty_312KHz(uint8 duty)
    uint8 target = 0,prescale=0;
    target = (duty>128)?(256-duty):duty;
    prescale = (target==0)?0:(target-1);
    //freq = 80000 (khz) /256 /duty_target * (prescale+1)
    set_sigma_target(duty);//SET DUTY TARGET
    set_sigma_prescale(prescale);//SET CLK DIV
sigma_delta.rar
(1.79 KiB) Downloaded 856 times
hadipic
Re: A first order sigma-delta signal from io pin source
Postby hadipic » Fri Aug 19, 2016 9:31 pm
hi
i have a qution
what (GPIO_SIGMA_DELTA_NUM) ?
i define
#define GPIO_SIGMA_DELTA_NUM 4 // modify for pin
for gpio4 but not output signal
help me
hadipic
Postby hadipic » Mon Sep 05, 2016 1:45 pm
hi
slove this problem i edit code
its work :D
target: duty ,0-255
#include "osapi.h"
#include "gpio.h"
#include "esp8266.h"
//uint32 GPIO_SIGMA_DELTA_NUM=0x68;
#define GPIO_SIGMA_DELTA_NUM  0x68
 // modify for pin
#define GPIO_SIGMA_DELTA      0x68  //defined in gpio register.xls
#define   PERIPHS_GPIO_BASEADDR   0x60000300
#define GPIO_SIGMA_DELTA_ADDRESS   (PERIPHS_GPIO_BASEADDR + 0x68)  //defined in gpio register.xls
 * Returns      : none
//GPIO_SIGMA_DELTA_NUM= 0x68;//GPIO_NUM;
  uint32 pinaddr = GPIO_PIN_ADDR(GPIO_ID_PIN(GPIO_NUM));
  //  PIN_FUNC_SELECT(GPIO_MUX, GPIO_FUNC);
  //  gpio_output_set(0,0,0x1<<GPIO_NUM,0);
   //gpio_output_set(1<<GPIO_NUM,0,1<<GPIO_NUM,0);
   // Make it output PWM signal
  GPIO_REG_WRITE(pinaddr, GPIO_REG_READ(pinaddr) | 1);
   GPIO_REG_WRITE(GPIO_SIGMA_DELTA, 0x1FFFF);
 * Returns      : none
    //gpio_output_set(0,0,0,0x1<<GPIO_NUM);
 * Returns      : none
    uint32 reg_r;
    //uint32 t_tar=target;
        reg_r=GPIO_REG_READ(GPIO_SIGMA_DELTA);
        reg_r= reg_r & 0xFFFFFF00 ;
        reg_r= reg_r|target;
        GPIO_REG_WRITE(GPIO_SIGMA_DELTA, reg_r);
 * Returns      : none
    uint32 reg_r;
     uint16 p_r=prescale;
        reg_r= reg_r & 0xFFFF00FF ;
        reg_r= reg_r|( p_r<<8);
 * Returns      : none
   uint32 relaystate=1;
void ICACHE_FLASH_ATTR relay_set(int on) {
  uint32 pin = 4;
  uint32 pinaddr = GPIO_PIN_ADDR(GPIO_ID_PIN(pin));
 uint32 GPIO_NUM=pin;
  // Make pin a GPIO pin
  // Set to H (Transistor off)
  gpio_output_set(1<<pin,0,1<<pin,0);
  // Value for 12.7V
