esp8266 01 not respond some at comends
Postby cardmaker » Sun Jun 04, 2017 3:01 am
they responde to these cmds like AT+CWMODE=3, AT+CWJAP,"xxxx but not respond by exemple just AT, or AT+GMR what can be this issue?
also at comand scan wifi AT+CWLAP they juste replay "scandone" and not the names of the networks, anyone can help?
many thanks
Re: esp8266 01 not respond some at comends
Postby pratik » Sun Jun 04, 2017 11:55 pm
Also, don't forget to use \r\n at the end of each command!
Postby cardmaker » Mon Jun 05, 2017 4:20 pm
i try these:
AI-v0.9.5.0 AT firmware.bin
ai-thinker-0.9.5.2.bin
ai-thinker-v.1.1.1.bin
ESP_8266_BIN0.92.bin
and others but same result.
i know must use \r\n at final
this cmds works: AT+RST, AT+CWMODE=3, AT+CWLAP(just responde "scandone" and not the list), AT+CWJAP="xxx","xxx",AT+CIPSTART="TCP","XXXXXX",XX
but this cmds are not working: AT, AT+GMR, AT+CIPSEND=X,AT+CWMODE=?
Postby pratik » Wed Jun 07, 2017 3:24 pm
Please try the new ones from:
https://github.com/espressif/ESP8266_NO ... ter/bin/at
Note that minimum 8 Mbit system flash is needed for the latest AT firmware. If you are using less, let me know, I will send you 4 Mbit AT firmware files.
Postby cardmaker » Thu Jun 08, 2017 7:20 pm
i try the new version like you said but still the same.
08-06-2017 12:09:26.610 [RX] - <NUL><CR><LF>
ets Jan 8 2013,rst cause:1, boot mode:(3,2)<CR><LF>
<CR><LF>
<CR><LF>
ets Jan 8 2013,rst cause:2, boot mode:(3,6)<CR><LF>
<CR><LF>
load 0x40100000, len 2408, room 16 <CR><LF>
tail 8<CR><LF>
chksum 0xe5<CR><LF>
load 0x3ffe8000, len 776, room 0 <CR><LF>
tail 8<CR><LF>
chksum 0x84<CR><LF>
load 0x3ffe8310, len 632, room 0 <CR><LF>
tail 8<CR><LF>
chksum 0xd8<CR><LF>
csum 0xd8<CR><LF>
<CR><LF>
2nd boot version : 1.6<CR><LF>
SPI Speed : 40MHz<CR><LF>
SPI Mode : QIO<CR><LF>
SPI Flash Size & Map: 8Mbit(512KB+512KB)<CR><LF>
jump to run user1 @ 1000<CR><LF>
ive been trying many diferent firmware and i note the working at cmds are always same ones this is strange. any ideia?
AT+RST - works
AT - dont work
AT-GMR - dont work
AT+CWLAP - only replay "scandone" and none the list
AT+CIPSTART - works
AT+CIPSEND - dont work
all the new cmds in version2.1.0 dont work
Postby cardmaker » Sun Jun 11, 2017 4:14 am
10-06-2017 21:05:29.745 [TX] - AT+RST<CR><LF>
10-06-2017 21:05:29.761 [RX] - bcn 0<CR><LF>
del if1<CR><LF>
usl<CR><LF>
<CR><LF>
ets Jan 8 2013,rst cause:1, boot mode:(3,6)<CR><LF>
<CR><LF>
tail 8<CR><LF>
chksum 0xe5<CR><LF>
tail 8<CR><LF>
chksum 0x84<CR><LF>
tail 8<CR><LF>
chksum 0xd8<CR><LF>
csum 0xd8<CR><LF>
<CR><LF>
<CR><LF>
mode : softAP(5e:cf:7f:10:bb:3c)<CR><LF>
add if1<CR><LF>
dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1)<CR><LF>
bcn 100<CR><LF>
10-06-2017 21:05:54.974 [TX] - AT+CWMODE=3<CR><LF>
10-06-2017 21:05:55.004 [RX] - mode : sta(5c:cf:7f:10:bb:3c) + softAP(5e:cf:7f:10:bb:3c)<CR><LF>
add if0<CR><LF>
10-06-2017 21:06:01.887 [TX] - AT+CWLAP<CR><LF>
10-06-2017 21:06:01.901 [RX] - f r0, scandone<CR><LF>
sta scan trace -28<CR><LF>
10-06-2017 21:06:19.637 [TX] - AT+CWMODE=1<CR><LF>
10-06-2017 21:06:19.655 [RX] - bcn 0<CR><LF>
del if1<CR><LF>
mode : sta(5c:cf:7f:10:bb:3c)<CR><LF>
10-06-2017 21:06:28.971 [TX] - AT+CWLAP<CR><LF>
10-06-2017 21:06:28.988 [RX] - f r-28, scandone<CR><LF>
sta scan trace -29<CR><LF>
10-06-2017 21:06:39.229 [TX] - AT<CR><LF>
10-06-2017 21:06:42.280 [TX] - AT<CR><LF>
10-06-2017 21:06:42.800 [TX] - AT<CR><LF>
10-06-2017 21:06:49.280 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:06:52.950 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:06:53.800 [TX] - AT+CIPSTATUS<CR><LF>
10-06-2017 21:07:32.202 [TX] - AT+GMR<CR><LF>
10-06-2017 21:07:34.312 [TX] - AT+GMR<CR><LF>
10-06-2017 21:07:34.731 [TX] - AT+GMR<CR><LF>
as you can see AT+CWLAP only respond scandone and not the list of avalable network.
and some others cmds never respond.
Postby pratik » Mon Jun 12, 2017 1:28 pm
