先放上我的源码。
* ESPRESSIF MIT License
* Copyright (c) 2016 <ESPRESSIF SYSTEMS (SHANGHAI) PTE LTD>
* Permission is hereby granted for use on ESPRESSIF SYSTEMS ESP8266 only, in which case,
* it is free of charge, to any person obtaining a copy of this software and associated
* documentation files (the "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all copies or
* substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include "ets_sys.h"
#include "osapi.h"
#include "ip_addr.h"
#include "mem.h"
#include "client.h"
#include "uart.h"
#include "os_type.h"
#include "upgrade.h"
#include "espconn.h"
#include "user_interface.h"
#include "smartconfig.h"
#include "airkiss.h"
uint8 UserBinStr[10];
LOCAL os_timer_t user_runtimer;
#define DEVICE_TYPE "gh_9e2cff3dfa51" //wechat public number
#define DEVICE_ID "122475" //model ID
#define DEFAULT_LAN_PORT 12476
LOCAL esp_udp ssdp_udp;
LOCAL struct espconn pssdpudpconn;
LOCAL os_timer_t ssdp_time_serv;
LOCAL struct station_config s_staconf;
uint8_t lan_buf[200];
uint16_t lan_buf_len;
uint8 udp_sent_cnt = 0;
const airkiss_config_t akconf =
(airkiss_memset_fn)&memset,
(airkiss_memcpy_fn)&memcpy,
(airkiss_memcmp_fn)&memcmp,
0,
uint32 ICACHE_FLASH_ATTR
user_rf_cal_sector_set(void)
uint32 rf_cal_sec = 0;
switch (size_map) {
rf_cal_sec = 128 - 5;
break;
rf_cal_sec = 256 - 5;
break;
rf_cal_sec = 512 - 5;
break;
rf_cal_sec = 1024 - 5;
break;
rf_cal_sec = 2048 - 5;
break;
rf_cal_sec = 4096 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
void ICACHE_FLASH_ATTR
user_rf_pre_init(void)
user_running(void)
os_timer_disarm (&user_runtimer);
os_printf("%s is running!\r\n" , UserBinStr );
os_timer_setfn(&user_runtimer,(os_timer_func_t *)user_running,NULL);
os_timer_arm(&user_runtimer,2000,0);
static void ICACHE_FLASH_ATTR ota_finished_callback(void *arg)
struct upgrade_server_info *update = arg;
if (update->upgrade_flag == true)
os_printf("[OTA]success; rebooting!\n");
system_upgrade_reboot();
else
os_printf("[OTA]failed!\n");
os_free(update->pespconn);
os_free(update->url);
os_free(update);
#define pheadbuffer "Connection: keep-alive\r\n\
Cache-Control: no-cache\r\n\
\r\n"
static void ICACHE_FLASH_ATTR handleUpgrade(uint8_t serverVersion, const char *server_ip, uint16_t port, const char *path)
const char* file;
uint8_t userBin = system_upgrade_userbin_check();
switch (userBin)
case UPGRADE_FW_BIN1: file = "user2.1024.new.2.bin"; break;
case UPGRADE_FW_BIN2: file = "user1.1024.new.2.bin"; break;
default:
os_printf("[OTA]Invalid userbin number!\n");
return;
uint16_t version=1;
if (serverVersion <= version)
os_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
return;
os_printf("[OTA]Upgrade available version: %d\n", serverVersion);
struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
os_memcpy(update->ip, server_ip, 4);
update->port = port;
os_printf("[OTA]Server "IPSTR":%d. Path: %s%s\n", IP2STR(update->ip), update->port, path, file);
update->check_cb = ota_finished_callback;
update->check_times = 20000;
update->url = (uint8 *)os_zalloc(512);
os_sprintf((char*)update->url,
"GET %s%s HTTP/1.1\r\n"
"Host: "IPSTR":%d\r\n"
pheadbuffer,
path, file, IP2STR(update->ip), update->port);
if (system_upgrade_start(update) == false) {
os_printf("[OTA]Could not start upgrade\n");
os_free(update);
else
os_printf("[OTA]Upgrading...\n");
/******* WIFI事件回调函数 ******/
void ICACHE_FLASH_ATTR wifi_event_handler_cb_cb(System_Event_t *event){
struct ip_info info;
switch(event->event)
case EVENT_STAMODE_CONNECTED:
os_printf("et connect to ssid %s, channel %d\n",
event->event_info.connected.ssid,
event->event_info.connected.channel);
break;
case EVENT_STAMODE_GOT_IP:
os_printf("ip:" IPSTR ",mask:" IPSTR ",gw:" IPSTR,
IP2STR(&event->event_info.got_ip.ip),
IP2STR(&event->event_info.got_ip.mask),
IP2STR(&event->event_info.got_ip.gw));
os_printf("\n");
char ip[4] = {119,23,42,111}; //ww.linzoe.cn的IP地址
os_printf("LLAMANDO!!\n");
handleUpgrade(2,ip,1122,"/");
/* const char remote_ip[4]={192,168,10,107}; //存放外部的IP地址
wifi_get_ip_info(STATION_IF,&info);
tcp_server_init((struct ip_addr *)remote_ip,&info.ip,8080);
// HttpReadFile("http://ww.linzoe.cn:1122/");
break;
default:
break;
/******* WIFI Station参数配置与连接AP(路由) ******/
user_set_station_config(void)
uint8 ssid[32] = "LinZeJS";
uint8 password[64] = "linze2016";
stationConf.bssid_set = 0; //need not check MAC address of AP
wifi_station_connect();
user_init(void)
os_printf("SDK version版本:%s\n", system_get_sdk_version());
// uart_init(74880,74880);
if ( system_upgrade_userbin_check( ) == UPGRADE_FW_BIN1 )
strncpy(UserBinStr , "user1.bin" , 9 );
else
strncpy(UserBinStr , "user2.bin" , 9 );
UserBinStr[9] = '\0';
os_printf( "%s is running!\r\n" , UserBinStr );
smartconfig_set_type(SC_TYPE_ESPTOUCH_AIRKISS); //SC_TYPE_ESPTOUCH,SC_TYPE_AIRKISS,SC_TYPE_ESPTOUCH_AIRKISS
os_printf("mode:%d\n", wifi_get_opmode());
wifi_set_event_handler_cb(wifi_event_handler_cb_cb); //event处理回调函数,出现相应event事件回调用该函数
user_set_station_config();
其中在user_init主函数里,只要我将
设置快连接模式加上,远程升级就会失败,注释掉这条函数后,远程升级就会成功,请问下是什么原因造成这种现象的?
打印Log如下:
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user1
rf cal sector: 123
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
SDK ver: 2.1.0(116b762) compiled @ May 5 2017 16:08:55
phy ver: 1134_0, pp ver: 10.2
SDK version版本:2.1.0(116b762)
user1.bin is running!
mode:1
mode : sta(18:fe:34:d3:f7:74)
add if0
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 15
cnt
connected with LinZeJS, channel 11
dhcp client start...
et connect to ssid LinZeJS, channel 11
ip:192.168.10.114,mask:255.255.255.0,gw:192.168.10.1
LLAMANDO!!
[OTA]Upgrade available version: 2
[OTA]Server 119.23.42.111:1122. Path: /user2.1024.new.2.bin
upgrade_connect 50160
[OTA]Upgrading...
upgrade_connect_cb
pusrdata = HTTP/1.1 200 OK
Content-Length: 256100
Last-Modified: Tue, 06 Jun 2017 02:11:52 GMT
Accept-Ranges: bytes
ETag: "2d503e436aded21:0"
Server: Microsoft-IIS/7.5
X-Powered-By: ASP.NET
Date: Tue, 06 Jun 2017 02:14:38 GMT
Connection: close
sumlength = 256100
sec_block 63
sec_block 63 exceed
upgrade_check
[OTA]failed!
upgrade_get_sum_disconcb 50480
为什么只加了一句函数,远程升级就会失败?
Re: 为什么只加了一句函数,远程升级就会失败?
Postby YONG_LI » Fri Jun 09, 2017 10:23 am
你讲的这个我了解,smartconfig和user_set_station_config只能任选其一,不过我的问题是,我暂时没有用smartconfig,而只是先设置了这个模式而已。
在没加这句设置函数前,远程升级是正常的,但加上这句函数后,远程升级就失败了,我对比了下打印的log,在没加smartconfig_set_type(SC_TYPE_ESPTOUCH_AIRKISS); 这句设置函数前,擦除的块是
sec_block 58
..........................................................erase sector=1 ok
upgrade_get_sum_disconcb 47512
erase sector=2 ok
erase sector=3 ok
erase sector=4 ok
erase sector=57 ok
erase sector=58 ok
不过在加了smartconfig_set_type(SC_TYPE_ESPTOUCH_AIRKISS);这句函数后,擦除的块就变成了
sumlength = 256100
sec_block 63
sec_block 63 exceed
upgrade_check
[OTA]failed!
所以我不知道为什么我仅仅只是加了一句函数,它擦去的块的位置就变了?
sec_block 58
erase sector=2 ok
erase sector=3 ok
erase sector=4 ok
erase sector=57 ok
erase sector=58 ok
sumlength = 256100
sec_block 63
sec_block 63 exceed
upgrade_check
[OTA]failed!
