SDK 1.1.0 does not boot when 80Mhz SPI clock selected
nver
Postby nver » Tue May 26, 2015 2:00 pm
Hi there,
I downloaded SDK 1.1.0 and it does not boot when I set 80Mhz SPI Flash speed in ROM header. The boot loader get stuck as shown below. It boot fine if I switch back to 40Mhz via ROM header.
This is a new issue in SDK1.1.0 because I have been running flash at 80mhz in SDK1.0.1 without any problem. My application need SPI Flah at 80MHz, please can you look into this as provide a fix/workaround.
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 80MHz
  SPI Mode       : QIO
jump to run user1 @ 1000
Re: SDK 1.1.0 does not boot when 80Mhz SPI clock selected
Postby ESP_Faye » Tue May 26, 2015 3:57 pm
Sorry for the inconvenience.
Please have a try with the boot_v1.3 , can it work right ?
boot_v1.3(b3).zip
(2.02 KiB) Downloaded 469 times
nver
Postby nver » Tue May 26, 2015 6:19 pm
No, it does not work with boot_v1.3 either.Also I tested boot_v1.4 with user1.bin from SDK 1.0.1 and it works fine. So looks like its not the bootloader issue.
nver
Postby nver » Wed May 27, 2015 6:13 pm
Hi Espressif
Is there any update on this ?
Btw, its not bootloader issue at all, I did another test using non FOTA binaries [eagle.app.v6.flash.bin at 0x0 and eagle.app.v6.irom0text.bin at 0x40000] where we dont have bootloader at all. But these binaries does not boot for SDK 1.1.0 at 80Mhz.
Switching back to 40Mhz work fine.
Please help.
Postby ESP_Faye » Wed May 27, 2015 6:33 pm
So sorry for the inconvenience,
please have a try with this patch http://bbs.espressif.com/viewtopic.php?f=5&t=508
nver
Postby nver » Wed May 27, 2015 7:16 pm
Many thanks.
it now works with 80Mhz settings. :)
I still need to test with logic analyser if clock is coming out correctly.
Thanks again for such a quick turn around.
scargill
Postby scargill » Wed Jun 03, 2015 12:07 pm
For those of us who have not used patches before here... I have SDK 1.1.0 - and I cannot boot my files either- I just get a constant stream of rubbish out of the serial port.
How do you apply the patch files which I note are libmain_patch_01.a, libsmartconfig_patch_01.a and libssl_patch_01.a
nver
Postby nver » Wed Jun 03, 2015 12:48 pm
Hi
These patches seem to be just new binaries with the fix so what i do is simply rename them e.g. libmain_patch_01.a to libmain.a and replace them in /lib folder.
hdrut
Postby hdrut » Thu Jun 04, 2015 3:08 am
I confirm they are not patches in the strict sense of the word. Just replacement files.
Greetings.
