The command AT+CWMODE_DEF not stores correctly in Flash
Postby marcoleo » Tue May 26, 2015 8:52 pm
The command AT + CWMODE_DEF not stores correctly in Flash.
Turning off and on the module, setting is lost (after 2 times?)
I suppose that the problem also involves other commands
Power ON
AT+RST
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1 @ 1000
r??9l
l`?
ready
AT+GMR ;Version
AT version:0.24.0.0(May 22 2015 19:20:14)
SDK version:1.1.0
compile time:May 22 2015 20:56:34
AT+CWMODE? ;Reading+CWMODE:2
AT+CWMODE_DEF=3 ;Setting AP+Sta OK
AT+CWMODE? ;Verify ok!+CWMODE:3
Cycle Power OFF/ON
?r?<?????b???~?n???r??#?n??;nr???;???l`nn?????r?????pp??<????b???~?n???r??#?n??
rnr???;???;?r???n???r??l`$`?|?????#l`$`?r??9l???b????bp?b???n??1?n???? ???r?n?
?????b?l??b?>??????b??br?`$`?n??????r?#?n?b??b??l`?
ready
AT+GMR ;Version
SDK version:1.1.0
+CWMODE:3
Cycle Power OFF/ON
r?<?????b??>~?n???r??#?n??;nr???;???l`nn?????r?????pp??<????b???~?n???r??#?n??
rnr???;????;?r???n??r??l`$`??|?????#l`?n?br???#??l??#?$?`?lr?<?????b??>~?n???r??
#?n??;nr???;??l`nn?????r?????pp??<????b???~?n???r??#?n??rnr???;????;?r???n???r??
l`$`??|??? ?#l`??n?br???#??l??#?$?`?l??;???rrr??9l???b????bp?b??n????n???? ???r?
n??????b?l??b????????b??br?`$`?n??????r?#?n?b??b??l`?
ready
AT+GMR
SDK version:1.1.0
AT+CWMODE?
+CWMODE:2 <<<<=============================================================== ;VERIFY BAD!!!!
It seems a problem of flash
I loaded my flash (25Q40 = 512K) as follows:
SPI Flash Config
Crystal Freq: 26M
SPI Speed 40Mhz
SPI Mode QIO
8Mbit Flash SIZE
SpiAutoSet -
boot_v1.4(b1).bin;0x0000;
user1.1024.new.2.bin;0x1000;
user2.1024.new.2.bin;0x41000;
blank.bin;0x7E000;
My flash address is correct?
Thanks in advance!
Power ON
AT+RST
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
SPI Speed : 40MHz
SPI Mode : QIO
r??9l
l`?
ready
AT+GMR ;Version
SDK version:1.1.0
Cycle Power OFF/ON
ready
AT+GMR ;Version
SDK version:1.1.0
+CWMODE:3
Cycle Power OFF/ON
ready
AT+GMR
SDK version:1.1.0
AT+CWMODE?
SPI Flash Config
Crystal Freq: 26M
SPI Speed 40Mhz
SPI Mode QIO
8Mbit Flash SIZE
SpiAutoSet -
blank.bin;0x7E000;
Thanks in advance!
Re: The command AT+CWMODE_DEF not stores correctly in Flash
Postby ESP_Faye » Wed May 27, 2015 10:37 am
Download and unzip the SDK_v1.1.0 http://bbs.espressif.com/viewtopic.php?f=5&t=481
You could find "4A-ESP8266__AT Instruction Set" in folder "document", "1. Preambles" shows the downloading address.
Choosing 1024KB flash:
blank.bin;0x7E000 and 0xFE000
Postby marcoleo » Wed May 27, 2015 2:11 pm
Programmed 25Q40 (512KB)
boot_v1.4 (b1) .bin; 0x0000;
user1.1024.new.2.bin; 0x1000;
blank.bin; 0x7E000 and 0xFE000 <== ok
The problem persists.
After the first cycle power OFF/ON CWMODE = 3 (OK)
After the second cycle power OFF/ON CWMODE = 2 (BAD !!)
Postby ESP_Faye » Thu May 28, 2015 10:14 am
Sorry that I didn't make myself clear.
AT_v0.22(based on SDK_v1.0.0)and version before, need to programm as 512KB flash,download as 512KB flash
AT_v0.23(based on SDK_v1.0.1)and later version,need to use actually 1024KB flash,programming as 1024KB flash,downloading as 1024KB flash
If your flash is 512KB, here is a method to use latest AT firmware http://bbs.espressif.com/viewtopic.php?f=16&t=400&start=10#p1599
Postby marcoleo » Thu May 28, 2015 2:51 pm
Thanks,
but i think espressif should release any version of precompiled firmware so users with esp modules with 512k flash can still use latest firmware.
