Field esp_pcb
amsjunior
Field esp_pcb
Postby amsjunior » Wed May 27, 2015 1:05 pm
Hi there,
the struct espconn has the following field:
espconn_handle esp_pcb;
I'm wondering if this field is used internally by the ESP connection management, or if it's a field that I can use to point to my own object, and then retrieve these it from the callbacks.
Thanks!
Antonio.
Re: Field esp_pcb
Postby ESP_Faye » Wed May 27, 2015 4:09 pm
Do you mean the "typedef void *espconn_handle;" in espconn.h ?
It can be used to point to user's own object, but we recommend to use "struct espconn" .
Here is a demo of TCP connection http://bbs.espressif.com/viewtopic.php?f=21&t=232
amsjunior
Re: Field esp_pcb
Postby amsjunior » Thu May 28, 2015 2:19 pm
Thanks Espressif_Faye.
I would like to pass my own object between callbacks. For example:
LOCAL void ICACHE_FLASH_ATTR
user_tcp_connect_cb(void *arg)
pespconn->esp_pcb = os_malloc(sizeof(my_custom_type));
espconn_regist_recvcb(pespconn, user_tcp_recv_cb);
user_tcp_recv_cb(void *arg, char *pusrdata, unsigned short length)
my_custom_type* my = (my_custom_type*) pespconn->esp_pcb;
// Do stuff with object (my)
Is that correct? Or is there another recommended way for passing data among callbacks?
Thanks!
Antonio.
Re: Field esp_pcb
Postby ESP_Faye » Fri May 29, 2015 9:50 am
please refer to this:
pespconn->reverse = os_malloc(sizeof(my_custom_type));
my_custom_type* my = (my_custom_type*) pespconn->reverse;
