In the ESP8266 Non-OS SDK API Reference, under wifi_send_pkt_freedom method it states,
Only after the previous packet was sent, and the sent callback is entered, the next packet is allowed to send. Otherwise, wifi_send_pkt_freedom will return “fail”.
How does one setup the sent callback? - I have set up espconn_regist_sentcb() before for TCP, but there does not seem to be such a method dedicated to promiscuous mode and the required espconn_regist_sentcb method requires an espconn structure that can only be configured with a TCP or UDP object. Since promiscuous mode is neither, what do I do? All examples that I have found on the Internet just brute force the wifi_send_pkt_freedom and let it fail... sometime trying multiple times immediately after each other expecting a different answer. I would rather check it being ready and only then create the message to be sent.
Thanks for your help.
How to setup sent callback for promiscuous mode
Inquisitor
- Contact:
Postby Inquisitor » Tue Oct 01, 2019 8:07 pm
https://InqOnThat.com
Inquisitor
- Contact:
Re: How to setup sent callback for promiscuous mode
Postby Inquisitor » Tue Oct 01, 2019 8:33 pm
My bad - I was trying to set it up on the receiving logic side...
wifi_set_promiscuous_rx_cb(callbackListen);
wifi_promiscuous_enable(1);
... when obviously, I should have seen:
int wifi_register_send_pkt_freedom_cb(freedom_outside_cb_t cb);
Users browsing this forum: No registered users and 267 guests
