[../library/webserver.h][WebServerConn_recv_callback][468]
Sending Config[../library/webserver.h][WebServerConn_connect_callback][441] - Client connected
[../library/webserver.h][HttpSendWithHeader][21] - Freeheap 12592 vs. 12592
HTTP Response sent bytes: 4885
scandone
[../library/webserver.h][HTMLConfigscan_done][38]
Heap allocated for SSID's: 2048 Freeheap: 15568
Heap allocated for SSID's left: 1968 Freeheap: 15568
(3,"Rob Stone-2G",-96,"34:6b:46:2d:4c:86",6)
[../library/webserver.h][HttpSendWithHeader][21] - Freeheap 7368 vs. 7368
Unable to send, need a moment to breath to free memoryE:M 8200
Fatal exception 29(StoreProhibitedCause):
�pc1=0x4000e1b2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
load 0x3ffe8000, len 2192, room 16
tail 0
chksum 0x8c
load 0x3ffe8890, len 22144, room 8
tail 8
chksum 0x1c
load 0x40100000, len 30784, room 0
tail 0
chksum 0x13
csum 0x13
����n�r��n|�llll`b��|r�l�n��n�l`��r�l�l�l`��r�l�l�l`��r�l���ڹ./library/../library/common.h][Common_UserInit][1412]
sleep disable
Starting ESP8266 Standard!
SDK version:2.1.0(116b762)
Loaded from: 0x00
Vdd33_Const: ff
data : 0x3ffe8000 ~ 0x3ffe8890, len: 2192
rodata: 0x3ffe8890 ~ 0x3ffedf10, len: 22144
bss : 0x3ffedf10 ~ 0x3fff4a48, len: 27448
heap : 0x3fff4a48 ~ 0x3fffc000, len: 30136
reset reason: 2
REASON_EXCEPTION_RST (29)
[GetEXCCount]
GET GetEXCCount 1
[StoreEXCCount] creating with: 2
epc1=0x4000e1b2, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
System halt!
I keep receiving the following exception, then I use this
[osboxes@osboxes Main]$ locate elf-objdump
/home/osboxes/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-objdump
[osboxes@osboxes Main]$ /home/osboxes/esp-open-sdk/xtensa-lx106-elf/bin/xtensa-lx106-elf-objdump -d Main.o -S --start-address=0x4000
Main.o: file format elf32-xtensa-le
Disassembly of section .irom0.text:
00004000 <init_ThermostatSettings+0xa0>:
4000: 000021 l32r a2, fffc4000 <user_init+0xfffb8e20>
4003: 000001 l32r a0, fffc4004 <user_init+0xfffb8e24>
4006: 0000c0 callx0 a0
4009: 000846 j 402e <init_ThermostatSettings+0xce>
400c: 280000 excw
400f: 0f .byte 0xf
4010: 0c1266 bnei a2, 1, 4020 <init_ThermostatSettings+0xc
0>
4013: 000021 l32r a2, fffc4014 <user_init+0xfffb8e34>
4016: 000001 l32r a0, fffc4018 <user_init+0xfffb8e38>
4019: 0000c0 callx0 a0
401c: 000386 j 402e <init_ThermostatSettings+0xce>
401f: 0f2800 excw
4022: 082266 bnei a2, 2, 402e <init_ThermostatSettings+0xc
e>
4025: 000021 l32r a2, fffc4028 <user_init+0xfffb8e48>
4028: 000001 l32r a0, fffc4028 <user_init+0xfffb8e48>
402b: 0000c0 callx0 a0
402e: 0f1d mov.n a1, a15
4030: b108 l32i.n a0, a1, 44
4032: a1f8 l32i.n a15, a1, 40
4034: 30c112 addi a1, a1, 48
4037: f00d ret.n
4039: 000000 ill
0000b1e0 <user_init>:
b1e0: f0c112 addi a1, a1, -16
b1e3: 3109 s32i.n a0, a1, 12
b1e5: 21f9 s32i.n a15, a1, 8
b1e7: 01fd mov.n a15, a1
b1e9: 020c movi.n a2, 0
b1eb: 000005 call0 b1ec <user_init+0xc>
b1ee: 020c movi.n a2, 0
b1f0: b6a232 movi a3, 0x2b6
b1f3: 000001 l32r a0, fffcb1f4 <user_init+0xfffc0014>
b1f6: 0000c0 callx0 a0
b1f9: 000005 call0 b1fc <user_init+0x1c>
b1fc: 000005 call0 b200 <user_init+0x20>
b1ff: 000021 l32r a2, fffcb200 <user_init+0xfffc0020>
b202: 000001 l32r a0, fffcb204 <user_init+0xfffc0024>
b205: 0000c0 callx0 a0
b208: 0f1d mov.n a1, a15
b20a: 3108 l32i.n a0, a1, 12
b20c: 21f8 l32i.n a15, a1, 8
b20e: 10c112 addi a1, a1, 16
b211: f00d ret.n
It seems that the address 0x4000e1b2 does not exist in Main.O as it ends on 0x4000b211... Anyone know any background details on how I can narrow down the root cause. Thank you!!
As for addtional detail, it seems in https://www.espressif.com/sites/default ... ses_en.pdf on page 3/4 that this may be more of a ROM issue?
Update: It seems that I found a feed of the obj dump on google.
memset:
4000e190: 743030 extui a3, a3, 0, 8
4000e193: 117380 slli a7, a3, 8
4000e196: 203370 or a3, a3, a7
4000e199: 117300 slli a7, a3, 16
4000e19c: 203370 or a3, a3, a7
4000e19f: 205220 or a5, a2, a2
4000e1a2: cee207 bbsi a2, 0, 4000e174 <memmove+0x128>
4000e1a5: d8e217 bbsi a2, 1, 4000e181 <memmove+0x135>
4000e1a8: 417440 srli a7, a4, 4
4000e1ab: 179c beqz.n a7, 4000e1c0 <memset+0x30>
4000e1ad: 1167c0 slli a6, a7, 4
4000e1b0: 665a add.n a6, a6, a5
4000e1b2: 0539 s32i.n a3, a5, 0
4000e1b4: 1539 s32i.n a3, a5, 4
4000e1b6: 2539 s32i.n a3, a5, 8
4000e1b8: 3539 s32i.n a3, a5, 12
4000e1ba: 10c552 addi a5, a5, 16
4000e1bd: f12567 blt a5, a6, 4000e1b2 <memset+0x22>
4000e1c0: 056437 bbci a4, 3, 4000e1c9 <memset+0x39>
4000e1c3: 0539 s32i.n a3, a5, 0
4000e1c5: 1539 s32i.n a3, a5, 4
4000e1c7: 558b addi.n a5, a5, 8
4000e1c9: 036427 bbci a4, 2, 4000e1d0 <memset+0x40>
4000e1cc: 0539 s32i.n a3, a5, 0
4000e1ce: 554b addi.n a5, a5, 4
4000e1d0: 046417 bbci a4, 1, 4000e1d8 <memset+0x48>
4000e1d3: 005532 s16i a3, a5, 0
4000e1d6: 552b addi.n a5, a5, 2
4000e1d8: 026407 bbci a4, 0, 4000e1de <memset+0x4e>
4000e1db: 004532 s8i a3, a5, 0
4000e1de: f00d ret.n
I think my program is crashing within a memset call.. Maybe one of my alloc's is sliently failing cauing memset in my userland code to trigger this exception?
https://0x04.net/~mwk/doc/xtensa.pdf <-- I then found this and looked up s32i.n and found this on page 78/662
Table 4–27. Code Density Option Instruction Additions
Instruction1 Format Definition
ADD.N RRRN Add two registers (same as ADD instruction but with a 16-bit encoding).
ADDI.N RRRN Add register and immediate (-1 and 1..15).
BEQZ.N RI16 Branch if register is zero with a 6-bit unsigned offset (forward only).
BNEZ.N RI16 Branch if register is non-zero with a 6-bit unsigned offset (forward only).
BREAK.N2 RRRN This instruction is the same as BREAK but with a 16-bit encoding.
L32I.N RRRN Load 32 bits, 4-bit offset
MOV.N RRRN Narrow move
MOVI.N RI7 Load register with immediate (-32..95).
NOP.N RRRN This instruction performs no operation. It is typically used for instruction alignment.
RET.N RRRN The same as RET but with a 16-bit encoding.
RETW.N3 RRRN The same as RETW but with a 16-bit encoding.
S32I.N RRRN Store 32 bits, 4-bit offset
if seems when executing S32I.N RRRN Store 32 bits, 4-bit offset it triggers the issue, This may be more information then I need but I think I have an idea of what is triggering it but I am uncertain on how to locate the calling function without laying a bunch of printf's everywhere. Anyone know how to get a callstack or get addtional details?
Update2:
So I appended this check to each of my alloc's before the memset's got to them and it seemed to have resolved the issue.
if (FormatedHTMLPage == 0x0)
os_printf("[%s][%s][%d] - Unable to Alloc memory, exiting\r\n", __FILE__ ,__func__, __LINE__);
return;
The larger issue is I only have about 25k of heap to have a client connect via WPA-PSK2 and then send it a detailed webpage.
The page itself is almost 8k in side. Anyone know of an easy way to send this waypage with dynamic configurations inside?
The way I have it now is its loaded in flash and it reads it into a GlobalVar at the start. Yes sadly this takes a var kinda like this
char webpage[8192] = SPiRead(WebpageInSPIRom)
Then I have to allocate another for sprintf to then change my variables before I shoot it off to the client.
Problem is thats 16k raw just to format the data in memory. Any pointers would be greatly appreciated!
Update3: Here is my latest error @ 0x40101074
IP Address: 192.168.1.51
Netmask : 255.255.255.0
Gateway : 192.168.1.1
Calling myConnectToStronestWifiCallback callback
[Main.c][EnterMaintainanceMode][537]
AP Already Loaded[../library/webserver.h][init_webserver][786]
Setting Callback for WebServer
[../library/dnsserver.h][init_dnsserver][170]
-=-=-=-=-=-=-=-=- START DumpSPItable -=-=-=-=-=-=-=-=-
Read from: 0x67004-0x67007, Pending ff: EOF!
-=-=-=-=-=-=-=-=- END DumpSPItable -=-=-=-=-=-=-=-=-
[init_igmp]
IGMP Joining: 3301a8c0 faffffef, joined
Fatal exception 9(LoadStoreAlignmentCause):
epc1=0x40101074, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x0�000000
tail 0
chksum 0xcd
load 0x3ffe8890, len 22224, room 8
tail 8
chksum 0x44
tail 0
chksum 0xc8
csum 0xc8
����n�r��n|�llll`b��|r�l�n��n�l`��r�l�l�l`��r�l�l�l`��r�l����5����c][user_init][765]
[../library/../library/common.h][Common_UserInit][1412]
sleep disable
Loaded from: 0x00
Vdd33_Const: ff
rodata: 0x3ffe8890 ~ 0x3ffedf60, len: 22224
bss : 0x3ffedf60 ~ 0x3fff4a98, len: 27448
heap : 0x3fff4a98 ~ 0x3fffc000, len: 30056
reset reason: 2
REASON_EXCEPTION_RST (9)
[GetEXCCount]
[StoreEXCCount] creating with: 1
epc1=0x40101074, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000003, depc=0x00000000
System halt!
Anyone know how to see the function call at address's greater then 0x40100000? With this new EPC1 value it seems its assigned to the mapping of IRAM1.. Am I on the right track, should I objdump the Main.o and review the offset 0x1074 within?
Any pointers in the right direciton would be greatly appreicated.
