Adafruit ESP8266 (ESP-12) Huzzah not responding to AT commands.
BayBayMan
Postby BayBayMan » Sat Jun 17, 2017 6:30 am
My esp8266 Huzzah breakout board was recently reflashed using the esp flash tool, with the NONOS SDK v2.0.0. I figured this would allow the esp to respond when sent AT commands through the arduino serial monitor, but it did not.
I'm part of a group that is building something that requires a wifi connection that communicates with the Arduino MEGA. For right now, I just want to get the esp to respond to AT commands. I have tried using Putty and Realterm, but I don't know if I am using it correctly. I was following some instructions from a user on the arduino forums that stated just opening the serial monitor and sending AT+GMR should return the firmware version. We get no responses, though.
When we flashed the esp8266 Huzzah, it stated it was successfully flashed. We used a FTDI console cable to flash the esp8266 huzzah, by the way.
Below are the settings we have for the flash tool.
Below is what we get after it was flashed.
Re: Adafruit ESP8266 (ESP-12) Huzzah not responding to AT commands.
Postby Her Mary » Wed Jun 28, 2017 3:20 pm
I just send AT commands from PC using a serial debug tool. It works fine..
Baudrate of AT firmware is 115200. And AT command ends with a new line (CR LF).
