hi, I'm using my esp8266 module as a TCP server. when sending data from multiple client devices it oftenly shows data missing, In that cases +ipd is missing in my received data. expecting your valuable suggetions and solutions on this issue.
My settings are as follows:
AT+CWMODE=1
AT+CWDHCP=0,0
AT+CIPSTA="STA_IP","GATEWAY","SUBNET MASK"
AT+CWJAP="SSID","PASS_WORD"
AT+CIPMUX=1
AT+CIPSERVER=1,2000 I'M USING PORT 2000
AT+CIPSTO=0
AFTER the setting , client devices starts connect to the server device and sends data.. the +ipd missing occures when data receives from multiple clients...........please help me to resolve this issue...
missing +ipd
Re: missing +ipd
Postby Her Mary » Wed Jun 28, 2017 3:42 pm
In some cases, for example, bad network environment, TCP may combine 2 packets to be 1 packet, but the data should never missing.
You can check whether the <length> is correct or not. For example, maybe you sent 2 packets of which length is 6, but what you got is a +IPD with length 12, that is normal, not a bug. It combines 2 packets to be 1.
+IPD,<length>:xxxxxxYou can check whether the <length> is correct or not. For example, maybe you sent 2 packets of which length is 6, but what you got is a +IPD with length 12, that is normal, not a bug. It combines 2 packets to be 1.
Re: missing +ipd
Postby vichu537 » Tue Aug 01, 2017 3:21 pm
Her Majesty wrote:In some cases, for example, bad network environment, TCP may combine 2 packets to be 1 packet, but the data should never missing.Code: Select all
hi,
thanks for the replay. But the data missing issue still exist in some rare events..
