新手,这个问题是为什么呢?
raysoap
新手,这个问题是为什么呢?
Postby raysoap » Thu Jun 29, 2017 3:18 pm
make all
make[1]: Entering directory '/cygdrive/d/ESP8266test/app'
make[2]: Entering directory '/cygdrive/d/ESP8266test/app/user'
make[2]: Leaving directory '/cygdrive/d/ESP8266test/app/user'
xt-xcc -L../lib -nostdlib -T../ld/eagle.app.v6.ld -Wl,--no-check-sections -Wl,--gc-sections -u call_user_start -Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lcrypto -lmain -ldriver user/.output/eagle/debug/lib/libuser.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
../lib/libmain.a(app_main.o): In function `flash_data_check':
(.irom0.text+0x7bc): undefined reference to `user_rf_cal_sector_set'
(.irom0.text+0x977): undefined reference to `user_rf_cal_sector_set'
make[1]: *** [../Makefile:381: .output/eagle/debug/image/eagle.app.v6.out] Error 1
make[1]: Leaving directory '/cygdrive/d/ESP8266test/app'
make: *** [Makefile:325: .subdirs] Error 2
Re: 新手,这个问题是为什么呢?
Postby ESP_Faye » Thu Jun 29, 2017 7:48 pm
您好,
请在您的 user_main.c 中添加如下代码:
 * FunctionName : user_rf_cal_sector_set
 * Description  : SDK just reversed 4 sectors, used for rf init data and paramters.
 *                We add this function to force users to set rf cal sector, since
 *                we don't know which sector is free in user's application.
 *                sector map for last several sectors : ABCCC
 *                A : rf cal
 *                B : rf init data
 *                C : sdk parameters
 * Parameters   : none
 * Returns      : rf cal sector
uint32 ICACHE_FLASH_ATTR
user_rf_cal_sector_set(void)
    uint32 rf_cal_sec = 0;
    switch (size_map) {
            rf_cal_sec = 128 - 5;
            break;
            rf_cal_sec = 256 - 5;
            break;
            rf_cal_sec = 512 - 5;
            break;
            rf_cal_sec = 1024 - 5;
            break;
            rf_cal_sec = 2048 - 5;
            break;
            rf_cal_sec = 4096 - 5;
            break;
        default:
            rf_cal_sec = 0;
            break;
    return rf_cal_sec;
void ICACHE_FLASH_ATTR
user_rf_pre_init(void)
Users browsing this forum: No registered users and 301 guests
