Strange problem with SDK v1.1
Postby Harold L. » Wed Jun 03, 2015 12:07 pm
If I flash the *new bin* file to a *fresh board*(which means the SPI Flash contains all 0xff ....), it'll failed to connect to the AP!
I've sure the following things:
1. 8266 can receive. If I set a wrong SSID, it'll say STATION_NO_AP_FOUND instead of 'STATION_CONNECT_FAIL'
2. the WIFI Tx signal from 8266 may very weak, if a put the board near the AP, my AP has log like this:
daemon.info hostapd: wlan0: STA 18:fe:34:9d:80:97 IEEE 802.11: authenticated
daemon.notice hostapd: wlan0: STA 18:fe:34:9d:80:97 IEEE 802.11: did not acknowledge authentication response
but if the distance is not that close, like 5m, AP would have no such log.
3. If I flash the old bin(build from SDK 0.9.4) first, it'll connect to AP stably at any distance. Now we'll not call it as a *fresh board* since the old bin has been flashed, now I flash the *new bin* to it, WIFI connection is OK!!!
4. The most strange things come: If I erase the *entire* flash though SPIEraseChip() then flash the *new bin*, it'll become a *fresh board* and failed to connect again!
2015-6-3:
After more tests, I found the 3 and 4 was a side-effect of my logic. The problem is more accurately described as follow: with the new SDK, if my code consumes some time before the WIFI connection was established, (e.g.start a timer running at 1HZ in the user_init, block for 100ms in each timer_cb), you may not connect to any AP with SDK 1.1
The same behavior is OK with the old SDK, and we really need to do things before WIFI connection was established!
2015-6-10:
Please see my posts below.
I hope you can offer some help.
Thanks!
Re: Strange problem with SDK v1.1
Postby Harold L. » Wed Jun 03, 2015 12:13 pm
1. STEP2 with 0
2. boot 1.2 + STEP2 with 1 and STEP5 with 3 or 5
3. boot 1.4 + STEP2 with 1 and STEP5 with 3 or 5
all behave the same.
Postby ESP_Faye » Wed Jun 03, 2015 7:06 pm
Could you provide your test code to us to duplicate this problem ?
Here is a demo code of ESP8266 station connecting router http://bbs.espressif.com/viewtopic.php?f=21&t=228
Please have a try and notice that "stationConf.bssid_set = 0; " has to be set.
Postby MacDog » Sun Jun 07, 2015 7:56 pm
I've tried two different AP and they both exhibit the same behavior.
It seems to me that there is a timeout in ESP being to short. This results in ESP trying a reconnect instead of waiting for the AP and acknowledge.
Postby Harold L. » Wed Jun 10, 2015 11:22 pm
But I found something more intresting: the 0x1fe000 region (RF parameters) matters a lot!
"ssid_bad.bin" is the dump of 0x1fe000 from a board that can not connects to AP, and "ssid_good.bin" dumps from a board that connects fine.
- ssid.gif (138.78 KiB) Viewed 13262 times
something there were different, but was set by the same c code.
I've no idea why the same c code configs WIFI SSID & PASSWD can write different RF parameters to 0x1fe000.
P.S. After I flashing the ssid_good.bin to the board which can not connect to AP, it becomes OK!
Postby MacDog » Tue Jun 23, 2015 3:57 am
I found the ESP-12E to be a lot better than the ESP-12. When using the ESP-12E it connects to the AP that the ESP-12 fails on.
I'm converting to using ESP-12E
Postby Harold L. » Sat Jul 04, 2015 2:35 am
connecting...
mode : sta(18:fe:34:9d:80:96)
add if0
f 0, .....scandone
.reconnect
f 0, ....scandone
.reconnect
f -240, ....scandone
.reconnect
f 0, ....scandone
.reconnect
.reconnect
f 0, ....scandone
.reconnect
.reconnect
f 0, ....scandone
Postby iothing » Sun Jul 05, 2015 4:59 pm
First I use esptool to write_flash 0x00000 blank512k.bin
This sets all bits in the flash to ones
C code section:
wifi_station_disconnect();
wifi_set_phy_mode(2); //11g Mode
wifi_set_opmode(1); //STA mode
char ssid[32] = "lambda";
char password[64] = "1234567890";
wifi_station_connect();
wifi_station_dhcpc_start();
Uart log:
291> mode : sta(18:fe:34:a6:55:5a)
295> add if0
296> f 0, scandone
3413> reconnect
3413> f 0, scandone
6528> reconnect
6529> f -240, scandone
9645> reconnect
9645> f 0, scandone
12761> reconnect
12762> f -240, scandone
15878> reconnect
15878> f 0, scandone
18994> reconnect
18994> f -240, scandone
22111> reconnect
22111> f 0, scandone
25227> reconnect
25227> f -240, scandone
28343> reconnect
28343> f 0, scandone
31459> reconnect
31459> f -240, scandone
34576> reconnect
34576> f 0, scandone
37692> reconnect
37692> f -240, scandone
40809> reconnect
40809> f 0, scandone
43925> reconnect
43925> f -240, scandone
47041> reconnect
The same problem happens if I set the esp8266 to be in AP mode, no client can connect. If I place the client (smarphone literally on top of the esp8266 antenna it can sometimes connect.
Once the connection succeeds I can increase the distance by 20 meters and still the connection is stable. So maybe it really has to do with the initial TX PWR settings stored in flash?!
Postby blubb » Sat Aug 01, 2015 6:59 am
In 11N mode I get this scandone/reconnect loop and as reason for the disconnect "auth_leave" is reported.
My router is a "TP-Link TL-WR1043ND" with DD-WRT firmware.
