Communication between two ESP8266 module
parmar7725274
Postby parmar7725274 » Thu Jun 04, 2015 1:02 am
I have written firmware to configure ONE ESP as AccessPoint and another one as a STATION. Both are working fine with router, I means ESP8266 with Station configuration is able to connect with router and Using my cell phone I can connect ESP8266 which have SoftAP configuration. That means both are working fine but when I’m trying to Connect each other without router, Its not happening. ESP8266 with station configuration gives error NO ap found.
Any help ?
Thanks in advance.
Re: Communication between two ESP8266 module
Postby ESP_Faye » Thu Jun 04, 2015 10:18 am
Here is a demo of ESP8266 station connects to AP http://bbs.espressif.com/viewtopic.php?f=21&t=228
Please notice that "stationConf.bssid_set = 0; " need to be set.
parmar7725274
Postby parmar7725274 » Fri Jun 05, 2015 1:41 am
Thanks for reply.
But unfortunateley I still facing same problem.
Here is code, which I'm using.
ESP-1 : SoftAp ( Access Point / SERVER )
void ICACHE_FLASH_ATTR
user_init()
os_delay_us(100);
#ifdef PLATFORM_DEBUG
ets_uart_printf("ESP8266 platform starting...\r\n");
#endif
struct softap_config apConfig;
struct ip_info ipinfo;
char ssid[33];
char password[33];
char macaddress[17];
char info[150];
wifi_softap_dhcps_stop();
if( wifi_get_phy_mode() != PHY_MODE_11N )
ets_uart_printf("*** Setting PHY_MODE ...\r\n");
wifi_set_phy_mode( PHY_MODE_11N );
if(wifi_get_opmode() != SOFTAP_MODE)
ets_uart_printf("ESP8266 not in SOFTAP mode, restarting in SOFTAP mode...\r\n");
#endif
wifi_set_opmode(SOFTAP_MODE);
//after esp_iot_sdk_v0.9.2, need not to restart
//system_restart();
IP4_ADDR(&ipinfo.ip, 10, 10, 10, 1);
IP4_ADDR(&ipinfo.gw, 10, 10, 10, 1);
IP4_ADDR(&ipinfo.netmask, 255, 255, 255, 0);
wifi_set_ip_info(SOFTAP_IF, &ipinfo);
wifi_get_macaddr(SOFTAP_IF, macaddr);
wifi_softap_get_config(&apConfig);
os_memset(apConfig.ssid, 0, sizeof(apConfig.ssid));
os_sprintf(ssid, "%s", WIFI_APSSID);
os_memcpy(apConfig.ssid, ssid, os_strlen(ssid));
if (wifi_get_opmode() == SOFTAP_MODE)
#ifdef WIFI_APWPA
os_memset(apConfig.password, 0, sizeof(apConfig.password));
os_sprintf(password, "%s", WIFI_APPASSWORD);
os_memcpy(apConfig.password, password, os_strlen(password));
apConfig.authmode = AUTH_WPA_WPA2_PSK;
#else
apConfig.authmode = AUTH_OPEN;
#endif
apConfig.channel = 1;
apConfig.max_connection = 4;
apConfig.ssid_hidden = 0;
wifi_softap_set_config(&apConfig);
os_delay_us(500000);
wifi_softap_dhcps_start();
os_sprintf(macaddress, MACSTR, MAC2STR(macaddr));
os_sprintf(info,"OPMODE: %u, SSID: %s, PASSWORD: %s, CHANNEL: %d, AUTHMODE: %d, MACADDRESS: %s PHU MODE : %d\r\n",
wifi_get_opmode(),
apConfig.ssid,
apConfig.password,
apConfig.channel,
apConfig.authmode,
macaddress,
wifi_get_phy_mode());
ets_uart_printf(info);
#endif
//BtnInit();
ets_uart_printf("ESP8266 platform started!\r\n");
#endif
}ESP-2 : Station mode ( CLIENT )
void platform_init( void )
uint8 ret;
char ssid[32] = "NeelKanth";
char password[64] = "1234512345";
struct station_config stationConf, stationConfig;
ret = wifi_station_disconnect( );
os_printf("\n\r wifi_station_disconnect : %d \n", ret);
//wifi_station_dhcpc_stop( );
//Setup wifi
os_printf(" Start in STATION mode: %d \r\n",wifi_get_opmode());
if( wifi_get_opmode() != STATION_MODE )
os_printf(" Start in STATION mode\r\n");
wifi_set_opmode( STATION_MODE ); // Station Mode
if( wifi_station_get_config( &stationConf ) )
os_memset( stationConf.ssid, 0, sizeof(stationConf.ssid) );
os_memset( stationConf.password, 0, sizeof(stationConf.password) );
os_sprintf( stationConf.ssid, "%s", ssid );
os_sprintf( stationConf.password, "%s", password );
//need not mac address
if( !wifi_station_set_config( &stationConf ) )
os_printf("Failed to set STATION MODE configuration\r\n");
// wifi_station_dhcpc_start( );
ret = wifi_station_connect ( );
os_printf("\n\r wifi_station_connect : %d \n", ret);
wifi_station_set_auto_connect(1);
if(wifi_station_get_config(&stationConfig))
os_printf("\nSTA config: OPMODE: %u, SSID: %s, PASSWORD: %s, PHy Mode : %d\r\n",
wifi_get_opmode(),
stationConfig.ssid,
stationConfig.password,
wifi_get_phy_mode() );
* FunctionName : user_init
* Parameters : none
* Returns : none
void user_init(void)
system_timer_reinit();
platform_init();
// network_init();
}Please Help me !!
Thanks in advance.
- Prakash.
Postby ESP_Faye » Fri Jun 05, 2015 10:11 am
Here is a demo of ESP8266 softAP configuration http://bbs.espressif.com/viewtopic.php?f=21&t=227
Please notice that call “wifi_softap_get_config” first,otherwise,softap_config.ssid_len or softap_config.beacon_interval may be random value.. This may cause connection fail.
parmar7725274
Postby parmar7725274 » Sat Jun 13, 2015 1:26 pm
Thanks for your help.
I'm facing some error. Can you take a look of log and suggest any solution ? Please.
SoftAp Log :
mode : sta(18:fe:34:9e:16:b5) + softAP(1a:fe:34:9e:16:b5)
add if0
add if1
bcn 100
add 1
aid 1
station: 18:fe:34:9e:18:21 join, AID = 1
station: 18:fe:34:9e:18:21 leave, AID = 1
rm match
add 1
aid 1
Station log :
mode : sta(18:fe:34:9e:18:21)
add if0
scandone
add 0
aid 1
pm open phy_2,type:2 0 0
cnt
reconnect
rm match
pm close 7 0 0/10001392
scandone
add 0
aid 1
cnt
reconnect
rm match
pm close 7 0 0/10001361
scandone
add 0
aid 1
cnt
reconnect
rm match
pm close 7 0 0/10000192
WiFi connecting fail
Regards,
Prakash P.
parmar7725274
Postby parmar7725274 » Sat Jun 13, 2015 1:44 pm
I tried with each combination of SOFTAP_MODE and STATIONAP_MODE for AccessPoint
and STATION_MODE and STATIONAP_MODE for Station.
Every time Facing Same problem.
Thanks & Regards,
Prakash P.
Postby ESP_Faye » Tue Jun 16, 2015 2:33 pm
Please try to add configuration of apConfig.beacon_interval
apConfig.beacon_interval = 100;
parmar7725274
Postby parmar7725274 » Wed Jun 17, 2015 1:40 am
Thanks for your humble help and spend your valuable time.
I had tried with above solution. But unfortunately it's still giving same problem.It's appreciated if you again take a look on log and suggest some solutions. please.
Again thanks for your help.
Thanks & regards,
Prakash P.
Postby ESP_Faye » Wed Jun 17, 2015 11:16 am
Espressif_Faye wrote:Hi,
Please pay attention on the softAP configuration demo,we recommended to call “wifi_softap_get_config” first,otherwise,softap_config.ssid_len or softap_config.beacon_interval may be random value.. This may cause connection fail.
Add codes below
apConfig.ssid_len = 0;
Or just try codes below
user_init()
#endif
char ssid[33];
char password[33];
char info[150];
os_printf("*** Setting PHY_MODE ...\r\n");
#endif
//wifi_get_macaddr(SOFTAP_IF, macaddr);
#if 1 //def WIFI_APWPA
#else
#endif
os_printf("wifi_softap_set_config %s %s!\r\n",apConfig.ssid, apConfig.password);
#if 1 //def PLATFORM_DEBUG
os_printf("ESP8266 platform started!\r\n");
#endif
parmar7725274
Postby parmar7725274 » Fri Jun 19, 2015 1:35 am
I appreciate your patience,and thanks for your help.
From first time I understand what you are trying to say and I did it. And I also use your sample code, but in both case I'm getting same output.even though I also try with starting dhcp in STATION mode but no luck.
In your sample code for AP and STATION settings, whatever is given I iust copied and flash it on chip, but that is also not working.
Thanks again for your help, Would you like to suggest some solutions ? Please...
Thanks & Regards,
Prakash P.
