TCP reconnetion error code -9 or -11
Postby SPENCER » Wed Jul 12, 2017 9:30 am
Hi, I'd like to know that what is the meaning of error code back from the TCP reconnetion back function. It gets err code(-11) or err code(-9) sometimes. I think that is why I can't connect to TCP server. Thanks so much.
Re: TCP reconnetion error code -9 or -11
Postby pratik » Mon Jul 24, 2017 6:39 pm
Here is a snippet from espconn.h which will be helpful!
Note that LwIP sources are open and you can check the error codes from source files easily. Takes a minute only
#define ESPCONN_OK 0 /* No error, everything OK. */
#define ESPCONN_MEM -1 /* Out of memory error. */
#define ESPCONN_TIMEOUT -3 /* Timeout. */
#define ESPCONN_RTE -4 /* Routing problem. */
#define ESPCONN_INPROGRESS -5 /* Operation in progress */
#define ESPCONN_MAXNUM -7 /* Total number exceeds the set maximum*/
#define ESPCONN_ABRT -8 /* Connection aborted. */
#define ESPCONN_RST -9 /* Connection reset. */
#define ESPCONN_CLSD -10 /* Connection closed. */
#define ESPCONN_CONN -11 /* Not connected. */
#define ESPCONN_ARG -12 /* Illegal argument. */
#define ESPCONN_IF -14 /* UDP send error */
#define ESPCONN_ISCONN -15 /* Already connected. */
#define ESPCONN_HANDSHAKE -28 /* ssl handshake failed */
#define ESPCONN_SSL_INVALID_DATA -61 /* ssl application invalid */
Users browsing this forum: No registered users and 295 guests
