HSPI Clock Polarity
0xPIT
HSPI Clock Polarity
Postby 0xPIT » Sun Jun 07, 2015 10:41 pm
how can I change the Clock Polarity for Hardware-SPI? I need the clock to be low-active instead of the default which is high-active.
I've been playing with SPI_CTRL2, but this did not work as advertised in the Register-Description Excel file.
I was unable to delay MOSI for half a cycle.
Any help? Any examples?
Thanks,
- pit
0xPIT
Re: HSPI Clock Polarity
Postby 0xPIT » Wed Jun 17, 2015 5:05 am
Bump
Hey Espressif, any help here please?
It's OK if it is not possible, I just need to know.
Thanks,
pit
OverKill
Postby OverKill » Thu Jun 18, 2015 10:41 am
I'm trying to figure out the same thing.
I'll post back if I find anything.
0xPIT
Postby 0xPIT » Thu Jul 09, 2015 2:07 am
Hello Espressif,
please dig out this information, can that be so hard?
Thanks again,
pit
User avatar
kolban
Postby kolban » Thu Jul 09, 2015 5:31 am
Howdy there,
Have you seen this document:
download/file.php?id=577
It is:
8Q-ESP8266 HSPI Host Multi-device API v1.0
If I look on page 6, I find a parameter called "clk_polar"
This is associated with the function called hpsi_master_dev_init().
Is this what you are looking for?
Neil
leeshine
Postby leeshine » Thu Jul 09, 2015 1:12 pm
是啊,希望你们增加这些接口 :D
0xPIT
Postby 0xPIT » Fri Jul 10, 2015 3:26 am
Thanks Neil, I could find
#define HSPI_FALLING_EDGE_SAMPLE()      SET_PERI_REG_MASK(SPI_USER(HSPI),  SPI_CK_OUT_EDGE)
#define HSPI_RISING_EDGE_SAMPLE()         CLEAR_PERI_REG_MASK(SPI_USER(HSPI),  SPI_CK_OUT_EDGE)
in the spi_overlap.* sources, will try soon.
Not sure if this is for slave mode, though, as it's called _SAMPLE.
