HSPI PORT OVERLAP MODE DEMO
costaud
Postby costaud » Mon Nov 24, 2014 2:06 am
This overlap mode means that the hspi module can be re-mapping to the spi port.
After setting the higher priority to the spi port than to the hspi port , the hardware arbiter will switch these two port automatically via controlling the separate CS pins.
In this mode , the two spi modules share the same pins, so that the hspi pin mux can be configured as gpios or other functions.
The key point is the overlap mode config:
void ICACHE_FLASH_ATTR
    hapi_overlap_init()
   //hspi overlap to spi, two spi masters on cspi
   SET_PERI_REG_MASK(HOST_INF_SEL, reg_cspi_overlap);
   //set higher priority for spi than hspi
   SET_PERI_REG_MASK(SPI_EXT3(SPI),0x1);
   SET_PERI_REG_MASK(SPI_EXT3(HSPI),0x3);
  SET_PERI_REG_MASK(SPI_USER(HSPI), BIT(5));
 //select HSPI CS2 ,disable HSPI CS0 and CS1
 CLEAR_PERI_REG_MASK(SPI_PIN(HSPI), SPI_CS2_DIS);
 SET_PERI_REG_MASK(SPI_PIN(HSPI), SPI_CS0_DIS |SPI_CS1_DIS);
 //SET IO MUX FOR GPIO0 , SELECT PIN FUNC AS SPI CS2
//IT WORK AS HSPI CS2 AFTER OVERLAP(THERE IS NO PIN OUT FOR NATIVE HSPI CS1/2)
 PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO0_U, FUNC_SPI_CS2);
In this demo , we drive a spi screen and share the data and clock lines with the spi flash.
Work with a gyroscope:
esp_iot_sdk_v0.9.2_hspi_overlap_141124.rar
(1.07 MiB) Downloaded 2442 times
User avatar
rudi
Re: HSPI PORT OVERLAP MODE DEMO
Postby rudi » Mon Nov 24, 2014 6:03 am
perfect!
txs costaud for sharing! will follow your's.
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
vitogeng
Postby vitogeng » Wed Dec 10, 2014 4:16 pm
Hi!
you demo is great, but I have a question, how is it reading data from spi?
costaud
Postby costaud » Sun Feb 15, 2015 12:01 pm
vitogeng wrote:Hi!
The hardware will toggle the CS line automatically.
mculibrk
Postby mculibrk » Sun Mar 22, 2015 11:23 am
Hi there!
Experimenting with overlapping SPI funcionality... giving the sensitivity/difficulties in debugging such setup (because of the running code accessing the primary SPI flash) I would ask for some clarifications.
So, the ESP has two SPI units, so called SPI (primary, where the flash is usually attached) and the HSPI (secondary, free for user). Each SPI module is using its set of SPI registers (#define REG_SPI_BASE(i) (0x60000200 - i*0x100)).
Which pins/functions are used for 2 and 4 bit SPI mode operation? I suppose the one labelled SPIxxx and HSPIxxx, right? If that's right the HSPI module cannot work in 2 or 4 bit mode because some pins overlap with the primary SPI module:
Is that right?
    MTDI_U.......... MTDI.........I2SI_DATA.....HSPIQ....GPIO12
    MTCK_U..........MTCK........I2SI_BCK.......HSPID....GPIO13
    MTMS_U..........MTMS........I2SI_WS........HSPICLK...GPIO14
    MTDO_U..........MTDO.......I2SO_BCK ......HSPICS....GPIO15
    U0RXD_U.........U0RXD......I2SO_DATA.....GPIO3......CLK_XTAL
    U0TXD_U.........U0TXD......SPICS1..........GPIO1......CLK_RTC
    SD_CLK_U........SD_CLK.....SPICLK.........GPIO6.....U1CTS
    SD_DATA0_U....SD_DATA0...SPIQ...........GPIO7.....U1TXD
    SD_DATA1_U....SD_DATA1...SPID...........GPIO8.....U1RXD
    SD_DATA2_U....SD_DATA2...SPIHD.........GPIO9.....HSPIHD
    SD_DATA3_U....SD_DATA3...SPIWP.........GPIO10.....HSPIWP
    SD_CMD_U ......SD_CMD......SPICS0.........GPIO11.....U1RTS
    GPIO0_U........GPIO0 ........SPICS2.........CLK_OUT
    GPIO2_U........GPIO2 ........I2SO_WS.......U1TXD.....U0TXD
I suppose the xSPIHD and xSPIWP pins/functions are the pins/bits 2 and 3 for 4-bit SPI mode? Or the 4-bit mode uses the SD_xxx functions/pins?
Can the HSPI module use 4-bit transfer when configured for SPI Overlap? (using the same pins as primary?)
The running code fetching is done using the SPI module, right? Changing the SPI registers will affect the code execution/fetching, right? And probably cause the chip resetting or hanging?
If using overlapping mode, how many bytes can be read/written in one "block" - 64 bytes/512 bits? As the buffer is 64 bytes (if using all for write or read) and the number of bits in REG_USR_xx_BITLEN is 9 bits?
How long/big are the chunks of data (well, code) handled by the primary SPI module for code execution? Does the CPU always read/write 64 bytes a time when accessing the SPI flash?
When SPI modules work in Overlap mode and a transfer is started, will it send the entire buffer in one "piece" or the transfer can be interrupted by the primary SPI module?
For example, if I put 24 bytes in SPI buffer and issue a 192 bit data transfer (REG_USR_MISO_BITLEN=191) are all the 24 bytes transferred without interruption (from the primary SPI module)?
How are the SPI modules sharing the pins? Equal priority or no?
For example, if I want to send 100KB of data though HSPI using 512 bit transfers, loading the hspi buffer on transfer complete interrupt and at the same time read some data from SPI flash with spi_flash_read(src, buf, )... how will the transfer look?
Pseudo code:
volatile char buffer[256];
hspi_transfer_end_ISR:
  memcpy(buffer, hspi_buffer)                   // fill hspi_buffer with new 64 bytes of data
  start new hspi transfer (512 bits)             // send out the hspi buffer
  end interrupt
main:
  start hspi transfer (SPI_CMD(SPI_USR)=1)
  repeat
      spi_flash_read(src, buffer, 256)
      do_calculations
      src=src+256
  until src < 10000
will the SPI access look like this:
HSPI: write 512 bits
SPI: read 512 bits
SPI: read 512 bits
etc
or more like this:
SPI: read 512 bits // spi_flash_read() is blocking, right
SPI: read 512 bits
SPI: read 512 bits
SPI: read 512 bits
SPI: read 512 bits
SPI: read 512 bits
SPI: read 512 bits
etc.
Also, how will the code execution (loading code from flash to IRAM) affect such "interrupt driven large/bulk" transfers on HSPI module?
Thanks for any info.
Regards,
costaud
Postby costaud » Wed Mar 25, 2015 12:21 pm
This overlap mode will swap the HSPI port to the main SPI port.
So if we control the HSPI lines it acts on the main SPI lines.
There is a hardware arbiter to decide which line(CS0/CS1/CS2) should be selected.
So we need to set the CS line for HSPI and SPI,
As well as to set the priority of HSPI and SPI, so that the flash ICACHE reading would be execute firstly by switching the CS line.
//set higher priority for spi than hspi,
So , in this mode , we write the LCD on HSPI port , it disable the main SPI CS , enable the HSPI CS line, since we swap the port already , it reflects on the SPI port.
But the FLASH would not be burned because of the automatic CS selection.
Meanwhile , we already set the SPI prior to the HSPI , so if there is a command on SPI, the hardware would switch to the SPI CS line, then, back to HSPI CS after it's done.
mculibrk
Postby mculibrk » Wed Mar 25, 2015 12:32 pm
First of all thanks for the fast response!
I'm aware of the stuff you just wrote.
I was wondering if you know what will happen when a large/long read/write is done simultaneously on both SPI and HSPI?
For example, I want to send 100K of data over the HSPI port (in overlap mode, using interrupts on transfer complete) and other code continues to execute so actually the primary SPI is also used for fetching code to ICACHE.
Will the SPI/HSPI "sharing" happens equally (one packet/transfer for SPI one for HSPI) or will the HW switch to SPI until all required is read and only then switch back to HSPI? (priority?)
Also, is it possible to configure two (or more) SPI flashes on the SPI bus? The HW has CS0, CS1... but how to tell the CPU at which address is mapped the flash? So it could select the appropriate CS line?
Is this possible?
ritesh
Contact:
Postby ritesh » Sat Nov 28, 2015 1:14 pm
I am newbie for ESP-WROOM-02 Module and started to work on it. I have flashed and started AT firmware successfully without any issue. I have also executed some AT commands on that module which works fine without any issue.
Now, I have one OLED LCD and I want to connect it over SPI Interface. I know that there are HSPI Lines which are shared with GPIOs and UART Pins in this ESP-WROOM-02 Module.
Does you demo esp_iot_sdk_v0.9.2_hspi_overlap will work for ESP-WROOM-02 Wifi Module with OLED LCD connected over HSPI Lines?
Do I need to change any configurations or code to work your demo with ESP-WROOM-02 Module?
Please provide me Hardware Connection Details to connect OLED LCD with ESP-WROOM-02 WIfi Module.
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
mgrunt
Postby mgrunt » Wed Apr 20, 2016 6:30 pm
Hello, I found this post over Google. I have question. It is possible connect to display any other SPI device (for example SRAM)? Or otherwise. It is possible connect to SPI to which it is attached FLASH two SPI device? If yes, how to setup CS for two device? Thank you a lot.
MG
valmik thakar
Postby valmik thakar » Tue Aug 02, 2016 2:35 pm
hi,
i want to connect two esp using SPI for freeRTOS SDK.
i got some libs but i don't find any function for make esp device as a slave.
so, can anyone guide me how can i make any esp device as a spi slave device in freeRTOS.
regards,
Valmik Thakar
