ESP-NOW coexist with Station
baoshi
Postby baoshi » Wed Jul 19, 2017 10:07 am
I'm testing ESP-NOW for lighting project but seems stuck.
The situation being:
The light under control is SLAVE. Button is the CONTROLLER.
I'm sending packet from controller to slave's SOFT_AP interface.
It works fine when the light (slave) is not connected to any WiFi AP.
However if the light connects to WiFi, no packet is received. The sender's callback gives statue=1, means failure.
Below is slave side testing code. From controller side whether I send to slave's station or soft_ap interface all failure.
The "app_light" program in ESP8266_LIGHT_WITH_MESH doesn't seems to have this restriction but I'm not able to test it.
Any help will be appreciated.
#include <user_interface.h>
#include <osapi.h>
#include <mem.h>
#include <os_type.h>
#include <gpio.h>
#include <espnow.h>
#include "espmissingincludes.h"
#include "uart.h"
void ICACHE_FLASH_ATTR user_rf_pre_init(void)
void printMacAddress(uint8_t* macaddr)
  int i;
  os_printf("{");
  for (i = 0; i < 6; i++)
    os_printf("0x");
    os_printf("%x", macaddr[i]);
    if (i < 5) os_printf(",");
  os_printf("}\n");
void ICACHE_FLASH_ATTR rcv_cb(u8 *macaddr, u8 *data, u8 len)
    size_t i;
    os_printf("Reveive ");
    for (i = 0; i < len; i++)
        os_printf("0x%x ", data[i]);
    os_printf("from ");
    printMacAddress(macaddr);
void ICACHE_FLASH_ATTR main()
    os_printf("System init done.\n");
    if (esp_now_init()==0) {
        os_printf("direct link  init ok\n");
        esp_now_register_recv_cb(rcv_cb);
    } else {
        os_printf("esp-now already init\n");
    //It is designed to send data from station interface of switch/controller to softap interface of light
    esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);  //role 1: switch   ;  role 2 : light;
#define STA_SSID    "AAA"
#define STA_PASSWORD  "BBB"
void ICACHE_FLASH_ATTR wifi_init(void)
    struct station_config sta_conf;
    // connect to our station
    os_bzero(&sta_conf, sizeof(struct station_config));
    wifi_station_get_config(&sta_conf);
    os_strncpy(sta_conf.ssid, STA_SSID, sizeof(sta_conf.ssid));
    os_strncpy(sta_conf.password, STA_PASSWORD, sizeof(sta_conf.password));
    wifi_station_disconnect();
    ETS_UART_INTR_DISABLE();
    wifi_station_set_config(&sta_conf);
    ETS_UART_INTR_ENABLE();
    wifi_station_connect();
    // Configure the UART
    uart_init(BIT_RATE_74880, BIT_RATE_74880);
    wifi_station_set_auto_connect(0); // Change to 1 doesn't work
    //wifi_init();
    system_init_done_cb(main);
Re: ESP-NOW coexist with Station
Postby ESP_Faye » Mon Jul 24, 2017 11:08 am
Please check the channel.
The channel of ESP-NOW should be the same as the channel of the AP which the light connects to.
baoshi
Postby baoshi » Wed Jul 26, 2017 1:46 pm
Thanks, that works.
But some observations:
1. I can only use esp_now_add_peer() to set a channel. esp_now_set_peer_channel returns success but channel never changes.
2. The esp_now_set_peer_channel documentation in the 2c-esp8266_non_os_sdk_api_reference_en.pdf seems incorrect
Cheers,
Baoshi
