FOTA custom Server
krishna
FOTA custom Server
Postby krishna » Wed Jul 19, 2017 6:39 pm
I am krishna,
I am using ESP8266 size of 4096KB, i want to upgrade my firmware using custom fota server.
Loaded user1.bin using NODEMCU FIRMWARE PROGRAMMER tool, and it is working fine.
And i kept user2.bin in my server, and i am able to down load the user2.bin(from address location : 0x81000), as i finish downloading i am calling system_upgrade_reboot(); function to upgrade but it is throwing an exception :
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
jump to run user2 @ 81000
Fatal exception (0):
epc1=0x60000001, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
please help me to come out of this problem.
Thanks & regards,
Krishna.
Re: FOTA custom Server
Postby Her Mary » Mon Jul 24, 2017 10:03 am
The upgrade is successfully, but your user2.bin cannot run.
Maybe you should check the compilation of your user2.bin.
krishna
Postby krishna » Mon Jul 24, 2017 7:50 pm
Hi Her Majesty,
First of all thank you very much for reply,
These are my compilation results,
Support boot_v1.4 and +
Generate user2.4096.new.6.bin successully in folder bin/upgrade.
boot.bin------------>0x00000
user2.4096.new.6.bin--->0x81000
/* This linker script generated from xt-genldscripts.tpp for LSP . */
/* Linker Script for ld -N */
MEMORY
  dport0_0_seg :                        org = 0x3FF00000, len = 0x10
  dram0_0_seg :                         org = 0x3FFE8000, len = 0x14000
  iram1_0_seg :                         org = 0x40100000, len = 0x8000
  irom0_0_seg :                         org = 0x40282010, len = 0x6B000
please let me know if there is any changes.
Thanks & regards,
Krishna.
Users browsing this forum: No registered users and 294 guests
