Hardware bug: UART1 TX level not mirrored in status register
RFZ
Postby RFZ » Sun Apr 19, 2020 1:58 am
I guess I may have found a bug in the ESP8266 hardware / UART1 interface. Bit 31 of register 0x60000F1C (UART1 status register) should mirror the TX level of UART1. However, I found it to be always 0.
A workaround is actually to enable loopback mode for UART1 and read bit 15 of register 0x60000F1C, which mirrors the RX level. Since UART1 is TX only (?) that's not a huge problem.
The code I used to test this can be found here:
https://www.esp8266.com/viewtopic.php?f=13&t=21169&start=12
I'd appreciate if someone can confirm this.
RFZ
Re: Hardware bug: UART1 TX level not mirrored in status register
Postby RFZ » Fri May 01, 2020 6:27 pm
Same for UART0
