Error to use AT+CIPSTART=... ERROR CLOSED
acuerol
Postby acuerol » Wed Jun 10, 2015 6:48 am
The problem is that I try to connect two ESP8266, one operate in Station mode and the second in AP mode. The problem is that, sometimes the connection is made, also I can send and receive data, however, it is lost and I cannot connect again, I'll describe the procedure:
1:
AT+CWMODE=1
AT+RST
 ets Jan  8 2013,rst cause:4, boot mode:(3,7)
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size : 4Mbit
jump to run user1
rl\0x8e\0x82\0xff
Ai-Thinker Technology Co. Ltd.
ready
AT+CIPMUX=1
AT+CIPSERVER=1
AT+CIFSR
+CIFSR:STAIP,"172.168.0.40"
+CIFSR:STAMAC,"18:fe:34:98:3a:4f"
2:
AT+CWMODE=2
AT+RST
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
  SPI Speed      : 40MHz
  SPI Mode       : QIO
jump to run user1
r\0x18\0x02\0x8e\0x1b\0xd1
ready
AT+CIPSTART="TCP","173.168.0.40",333
ERROR
CLOSED
In both the AT+GMR output is:
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
Thanks for help!
Re: Error to use AT+CIPSTART=... ERROR CLOSED
Postby ESP_Faye » Wed Jun 10, 2015 11:42 am
Here is our latest AT firmware http://bbs.espressif.com/viewtopic.php?f=5&t=554
Download and unzip the attachment, in \esp_iot_sdk\document , please refer to "4B-ESP8266__AT Command Examples"
You need to use command AT+CWJAP="SSID","password" to connect to router first.
acuerol
Postby acuerol » Wed Jun 10, 2015 7:55 pm
Solved!
You are right, the situation was that the module sometimes connect automatically with my other module, this is the reason for the eventual error.
Thank you very much Espressif_Faye.
