overlape enabled,amplitude of spi clock is only around 2V
Postby mikewang » Wed Jun 10, 2015 12:32 pm
here comes the problem with the overlap function of hspi.
1.when overlap disabled, hspi could work successfully to communicate with alternative flash ic;
2.when overlap function enabled to reflect hspi port to program spi port to save pins, time consequence come out as expected, however the amplitude of hspi clock signal is only round 2 voltage showed in followed picture. A pull-up resistor has been tried, but it does not work bothering me so much. i will really appreciate it so much if u guys have any ideas about this situation!
- Attachments
- hspi overlap spi clock signal
- IMG_20150609_193259.png (454.3 KiB) Viewed 11037 times
Re: overlape enabled,amplitude of spi clock is only around 2
Postby Helios » Wed Jun 10, 2015 2:00 pm
Actually, the high-level part waveform may be the cycles of the 80MHz clock.
Please select SPI-Flash as 40MHz during downloading.
In overlap mode, SPI-Flash and HSPI must be one of the following cases:
1) both are 80MHz
2) none is 80MHz. For example, SPI-Flash is 40MHz, the other device is 10MHz
Postby mikewang » Wed Jun 10, 2015 2:59 pm
Helios wrote:Due to the bandwidth of oscillograph, it seems to be a 2V high-level.
1) both are 80MHz
first,thanks for your prompt reply,but there still some information needing to be shared with u ,
it gonna implemented by the way of answering ur question
not exactly, oscillograph has the ability to show 3.3V high-level clock waveform completely with some kind of distortion when overlap disabled ,but anyway is still works
actually i do not has any ideas about this , i gonna spend more time in observing this phenomenon.
1) both are 80MHz
2) none is 80MHz. For example, SPI-Flash is 40MHz, the other device is 10MHz[/quote]
when image downloaded , 40Mhz mode was selected which means spi-flash clock was 40Mhz and device clock was 10Mhz in my case accidently in accordance to ur requirement 2
hope for further explanation!
thank you so much!
Postby Helios » Wed Jun 10, 2015 4:31 pm
I guess it is a PCB problem.
I suggest that we can insert a serial resistance (200ohm) between ESP8266 SPI-CLK pin and the two spi-slaves (Flash and the device).
Then you can check the waveforms of the two end of the resistance.
The digital pad of ESP8266 can drive 20mA current. So it shall be a voltage on the resistance.
Postby mikewang » Wed Jun 10, 2015 5:55 pm
Helios wrote:Thanks for your trying and patience.
thank you so much
fine,from ur suggestion, it is doubted that this situation may be caused by a heavy load, so the resistor is used to test the current flowing through 200ohm resistor,right?
however i got one more thing u need to know that the waveform in the picture was captured when leaving the clock pin float,so the device has exactly no affect on the clock pin. anyway i gonna try ur suggestion out.
Postby mikewang » Mon Jun 15, 2015 10:48 am
hi buddy:
ur suggestion has been tried out these days , but no signature potential difference existed between resistor(200ohm) which can implied that there is no heavy load attached to this pin. ahm, this almost drive me crazy these days without figuring this out
Postby ESP_Faye » Mon Jun 15, 2015 10:59 am
We released a documentation about SPI overlap http://bbs.espressif.com/viewtopic.php?f=5&t=591
Could it help?
Postby Helios » Mon Jun 15, 2015 12:57 pm
Please do a more try: setting the Flash-clock as 20MHz during downloading.
If software exceptions occur, it means a register bit of SPI is wrong.
Please also check the clock waveform of Flash. It shall be 20MHz regarding to your settting.
Postby nissimzur » Mon Jun 15, 2015 4:56 pm
2V as "high" is OK in system that has 3.3V a VCC. Since all the chip CMOS and any voltage above 1.65V is high.
Other potential error is your power supply that may not deliver read good 3.3V @ 0.5A , use other laboratory power supply and add on the chip fast capacitors (fast discharge). The ringing on top of the 2V has to go!
Skype:nissim.test
Dr. Nissim Zur
Bluetooth Smart, IoT expert
CTO Elinistech
Linkedin http://lnkd.in/TTnsGz
Email nissim@vitelix.com
Skype:nissim.test
Users browsing this forum: No registered users and 24 guests
