ESP8266 ESP_IDF开发环境配置问题
BitFu
Postby BitFu » Fri May 08, 2020 2:52 pm
按下面链接配置的编译环境
https://docs.espressif.com/projects/esp8266-rtos-sdk/en/latest/get-started/windows-setup.html
编译时出现下面这些警告,是什么原因,是否影响正常的编译?
可否屏蔽???
fatal: 不是一个 git 仓库(或者任何父目录):.git
WARNING: Toolchain version is not supported: 1.22.0-100-ge567ec7
Expected to see version: 1.22.0-92-g8facf4c
Please check ESP-IDF setup instructions and update the toolchain, or proceed at your own risk.
Please download and use the toolchain from the URL of README.md
Re: ESP8266 ESP_IDF开发环境配置问题
Postby Her Mary » Mon May 11, 2020 10:38 am
建议用 ubuntu 环境开发吧
实在要用 windows 的话,可以试试这个虚拟机 http://download.espressif.com/esp_share ... tu1804.ova
Users browsing this forum: No registered users and 258 guests
