LWIP build failure with ESP8266_RTOS_SDK
cmarrin
Postby cmarrin » Thu May 28, 2020 7:30 am
I decided to try the latest released ESP8266_RTOS_SDK. I installed the latest toolchain:
    xtensa-lx106-elf-macos-1.22.0-100-ge567ec7-5.2.0.tar.gz
Then I cloned the release/v3.3 branch of ESP8266_RTOS_SDK. This caused the build to fail on my project with:
CC build/lwip/lwip/src/api/if_api.o
In file included from /Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/api/if_api.c:49:0:
/Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/include/lwip/priv/sockets_priv.h:105:0: warning: "LWIP_SETGETSOCKOPT_MAXOPTLEN" redefined
 #define LWIP_SETGETSOCKOPT_MAXOPTLEN LWIP_MAX(16, sizeof(struct ifreq))
In file included from /Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/include/lwip/priv/sockets_priv.h:45:0,
/Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/include/lwip/sockets.h:115:0: note: this is the location of the previous definition
 #define LWIP_SETGETSOCKOPT_MAXOPTLEN 16
/Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/include/lwip/priv/sockets_priv.h:109:8: error: redefinition of 'struct lwip_setgetsockopt_data'
 struct lwip_setgetsockopt_data {
/Users/cmarrin/esp/ESP8266_RTOS_SDK/components/lwip/lwip/src/include/lwip/sockets.h:119:8: note: originally defined here
cc1: warning: unrecognized command line option '-Wno-frame-address'
make[1]: *** [/Users/cmarrin/esp/ESP8266_RTOS_SDK/make/component_wrapper.mk:292: lwip/src/api/if_api.o] Error 1
make: *** [/Users/cmarrin/esp/ESP8266_RTOS_SDK/make/project.mk:571: component-lwip-build] Error 2
So I went back to the examples and tried building:
    ESP8266_RTOS_SDK/examples/get-started/hello_world
and got the same error. It looks like there's some conflict in including two different headers with the same definitions. Has anyone seen this? For the hello_world example I first ran 'make menuconfig' using all the default values.
Re: LWIP build failure with ESP8266_RTOS_SDK
Postby Her Mary » Tue Jun 09, 2020 6:29 pm
Same issue?https://github.com/espressif/ESP8266_RTOS_SDK/issues/892
Users browsing this forum: No registered users and 257 guests
