ESP8266_NONOS_SDK_V1.1.2_15_06_12
Admin
Site Admin
Postby Admin » Fri Jun 12, 2015 9:53 pm
请勿使用本旧版本 SDK,建议使用 最新发布 SDK。
AT firmware is not updated in ESP8266_NONOS_SDK_V1.1.2, the latest AT is still AT_0.25_SDK_v1.1.1 !
ESP8266_NONOS_SDK_V1.1.2_15_06_12 Release Note
Optimization:
1. support certificate issuer verification for SSL
2. Update SPI driver, support overlap mode
Add APIs:
1. wifi_station_set_hostname : set ESP8266 station DHCP hostname
2. wifi_station_get_hostname : get ESP8266 station DHCP hostname
3. spi_flash_set_read_func :set user specified reading SPI function on overlap mode
4. espconn_secure_ca_disable : disable SSL CA verify
5. espconn_secure_ca_enable : enable SSL CA verify
Add Documentation:
1. SPI overlap introduction: \esp_iot_sdk\document, sorry that it has only Chinese version now,we will add English version of this documentation ASAP.
2. SSL introduction: \esp_iot_sdk\document
优化:
1. SSL支持认证的签发校验;
2. spi driver更新,并增加overlap模式;
新增 APIs:
1. wifi_station_set_hostname : 设置 ESP8266 station DHCP hostname
2. wifi_station_get_hostname : 查询ESP8266 station DHCP hostname
3. spi_flash_set_read_func :用于overlap模式定义用户读取spi接口
4. espconn_secure_ca_disable : 关闭 SSL CA 验证功能
5. espconn_secure_ca_enable : 开启 SSL CA 验证功能
新增文档:
1. SPI overlap 介绍: \esp_iot_sdk\document
2. SSL 使用说明: \esp_iot_sdk\document
ESP8266_NONOS_SDK_V1.1.2 没有 AT 相关的更新,因此最新 AT 固件仍然是 AT_v0.25_SDK_v1.1.1 !
esp_iot_sdk_v1.1.2_15_06_12.zip
(11.11 MiB) Downloaded 13926 times
Re: ESP8266 SDK (esp_iot_sdk_v1.1.2_15_06_12)
Postby ESP_Faye » Tue Jun 30, 2015 10:33 am
Document "2C-ESP8266__SDK__Programming Guide" updates for fixing some mistakes.
Sorry for the inconvenience.
2C-ESP8266__SDK__Programming Guide__EN_v1.1.2.pdf
(923.74 KiB) Downloaded 1632 times
2C-ESP8266__SDK__Programming Guide__CN_v1.1.2.pdf
(1.25 MiB) Downloaded 2416 times
Users browsing this forum: No registered users and 21 guests
