My new ESP-WROOM-02 cannot boot up from flash
icomet
Postby icomet » Sat Jun 13, 2015 11:43 am
I want to use the example in IOT Sdk1.1.1 to start. I copied souce code from /examples/IoT_Demo to /app without any modification, and use 1,1,2,0,4 for step 1-5 to generate bin;
My flash tool configurations as below:
flash
But after I power off, switch to flash boot mode, power on, I get no log from UART0 and UART1; and switch back to UART downloading mode, I got log "ets Jan 8 2013,rst cause:1, boot mode:(1,7)";
Need I to modify source code of IoT demo in order to run on my hardware? or there is something I did wrongly?
Re: My new ESP-WROOM-02 cannot boot up from flash
Postby ESP_Faye » Mon Jun 15, 2015 10:47 am
It seems that your hardware settings is not correct.
While downloading, it is MTDO: 0, GPIO0: 0, GPIO2: 1
While boot up from flash, it is MTDO: 0, GPIO0: 1, GPIO2: 1
If your problem is still unsolved, please take a picture of your hardware board, we will help you check it.
icomet
Postby icomet » Mon Jun 15, 2015 11:27 am
Thanks. I finally found the wrong state of my hardware. Now it's ok.
Users browsing this forum: No registered users and 24 guests
