Trying to develop something using esp-now.
It seems that, there is no way for a sender and receiver to agree upon some common secret before communication. As long as the sender knows receiver's mac address, sender can always send data to receiver.
I tried esp_now_set_kok, and with/without esp_now_add_peer, all does not work. A sender can always send data to receiver with default kok and use esp_now_send with receiver's mac address.
Is this the correct implementation?
What is the security model of esp-now
Re: What is the security model of esp-now
Postby ESP_Faye » Tue Aug 15, 2017 5:41 pm
Do you set the parameter "key" when calling esp_now_add_peer?
That "key" is used to encrypt the ESP-NOW communication.
Postby drstefa » Thu Feb 22, 2018 1:14 am
I got the same problem.
On master i set esp_now_set_kok with the key and add peer using the same key. Master send data and esp_now_register_recv_cb is correct fired.
On slave i set esp_now_set_kok with the key but esp_now_register_recv_cb will not fired.
Same code without using key works fine and correctly.
How could i check?
How could i check?
Postby Her Mary » Sat Feb 24, 2018 2:17 pm
Could this ESP-NOW guide help?
