Timout immediately reconnects
mvandere
Postby mvandere » Tue Jun 16, 2015 8:59 am
I'm using an ESP-12 and AT commands 25 and I am finding that when device is set as a TCP server it reconnects immediately after a timeout disconnection.
Here's a log
AT+CWMODE_CUR=3
AT+CWSAP_CUR="ESP8266","",5,0
AT+CIFSR
+CIFSR:APIP,"142.255.49.94"
+CIFSR:APMAC,"c5:7c:fe:06:ff:ff"
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"00:56:52:04:32:20"
AT+CIPMUX=1
AT+CIPSERVER=1,1001
0,CONNECT
+IPD,0,1:s
+IPD,0,1:s
+IPD,0,1:s
+IPD,0,1:s
+IPD,0,1:s0,CLOSED
0,CONNECT
0,CLOSED
0,CONNECT
0,CLOSED
0,CONNECT
0,CLOSED
0,CONNECT
The client (als an ESP-12) connected sent the noted 's' characters and then just sat there sending nothing further. The port 'closed' and immediately reconnected every three minutes (the 180 second default). Shouldn't it have stayed closed?
Re: Timout immediately reconnects
Postby ESP_Faye » Tue Jun 16, 2015 2:10 pm
It seems that your TCP client is trying to reconnect, not ESP8266.
Please create TCP client with another tool , for example , "NetAssist.exe" or "TCP&UDPDebug" , and try it again.
mvandere
Postby mvandere » Tue Jun 16, 2015 3:09 pm
The client is another ESP8266.
Is that normal for the ESP8266 to try and reconnect?
Is there a way to turn that on and off?
Postby ESP_Faye » Tue Jun 16, 2015 4:15 pm
What's the AT version are you using , you can get it by command "AT+GMR"
Are you using our official AT firmware (\esp_iot_sdk_v1.1.1\bin\at) ?http://bbs.espressif.com/viewtopic.php?f=5&t=554
Sorry that I can't duplicate your problem, could you offer your test steps ?
Serial-COM6 is the ESP8266 as softAP and TCP server, Serial-COM7 is another ESP8266 as station and TCP client. Here is my test result, it works fine.
mvandere
Postby mvandere » Wed Jun 17, 2015 3:04 pm
Here's a log from the server with your commands
AT+GMR
AT version:0.25.0.0(Jun  5 2015 16:27:16)
SDK version:1.1.1
compile time:Jun  5 2015 21:03:10
AT+CWSAP_CUR="8266","88888888",5,3
AT+CIPMUX=1
AT+CIPSERVER=1,1112
AT+CIFSR
+CIFSR:APIP,"192.168.4.1"
+CIFSR:APMAC,"1a:fe:34:a6:62:d7"
+CIFSR:STAMAC,"18:fe:34:a6:62:d7"
AT+CIPSTO=10
0,CONNECT
+IPD,0,4:12340,CLOSED
0,CONNECT
+IPD,0,4:ABCD0,CLOSED
0,CONNECT
0,CLOSED
0,CONNECT
0,CLOSED
0,CONNECT
0,CLOSED
Here's a log from the client with your commands, plus a couple of mine at the end
AT+GMR
SDK version:1.1.1
WIFI GOT IP
AT+CIPSTART="TCP","192.168.4.1",1112
CONNECT
AT+CIPSEND=4
Recv 4 bytes
SEND OK
ERROR
AT+CIPMODE=1
CONNECT
AT+CIPSEND
So it looks like it's the AT+CIPMODE=1 command that causes the client to immediately reestablish the timed out session with the server. Is that 'as designed'? If so, perhaps it should be documented in the manual?
Postby ESP_Faye » Wed Jun 17, 2015 4:01 pm
yes, “AT+CIPMODE=1” enter UART-WiFi passthrough mode,if connection broke,ESP8266 will always retry to connect to TCP server unless using “+++” and “AT+CIPMODE=0” to quit from UART-WiFi passthrough mode.
Thanks for your advice,we will add this description in the documentation.
