espconn_secure_connect: how does it work?
ESP_Sprite
Postby ESP_Sprite » Thu Nov 27, 2014 7:24 am
I'm developing an application that needs to connect to a SSL server (specifically, an XMPP server), but I'm running into trouble with espconn_secure_connect and friends. When I use espconn_connect, everything works, but with espconn_secure_connect, I either get
"client handshake start."
on the console and then nothing, or an exception:
"Fatal exception (29):
epc1=0x4000df3a, epc2=0x00000000, epc3=0x00000000, excvaddr=0x181869fe, depc=0x00000000"
What I get is dependent on the server I connect to.
Just to check: do I need something valid in cert.h and/or private_key.h? At the moment, I have what I think is a self-signed certificate in those files, but I couldn't really find any documentation on those. I also don't quite know if they're needed for a client-side connection. Could you shed some light on those things?
ESP_Sprite
Re: espconn_secure_connect: how does it work?
Postby ESP_Sprite » Fri Nov 28, 2014 6:20 am
That's all somewhat unfortunate: it makes it pretty much impossible to use SSL for anything but services that are specifically meant for the ESP. Ah well, for three bucks, I still can't complain.
ESP_Sprite
Postby ESP_Sprite » Fri Nov 28, 2014 4:29 pm
jackon wrote:hi, Sprite_tm
Could you provide your SSL server's ip and port?
We will have a test.
Sure. I've tried it on two servers, both my HTTPS as well as a SSL Jabber server I don't manage myself. Connecting to the https server makes the esp reboot, connecting to the Jabber server stalls the connection. Both connect fine using for example openssl s_client -connect spritesmods.com:443
The https server is at
https://spritesmods.com/ (port 443, as usual)
The jabber server I tried is at
jabber.hot-chilli.net:5223
ESP_Sprite
Postby ESP_Sprite » Fri Nov 28, 2014 7:44 pm
I'd really like a patch for 0.9.3 to try! Thanks for looking into the problem.
Postby jackon » Fri Nov 28, 2014 9:36 pm
Just extra the libssl.a to SDK's lib folder.
Or you can modify ssl_tls1.h, line 80.
#define RT_MAX_PLAIN_LENGTH 4096Give me feedback after your test.
Thx
- Attachments
- libssl.zip
- (55.05 KiB) Downloaded 830 times
ESP_Sprite
Postby ESP_Sprite » Sat Nov 29, 2014 4:29 pm
Ah, while I'm asking questions about SSL etc, does the SDK already have a method to do opportunistic TLS? That basically involves setting up a plaintext connection, asking the server if you can continue using encryption and then doing the SSL handshake over the same socket you previously did plaintext over. If not, I may implement it myself.
Postby mathijs » Wed Dec 03, 2014 5:49 pm
I had the same problem when connecting to 'official signed' HTTPS servers. After changing the buffersize to 4096 instead of 1024, the HTTPS connection works fine now!
Thanks!
Postby younger » Fri Jan 02, 2015 3:51 pm
jackon wrote:Here is the patch, we test to connect your server, it works OK, you can check by yourself.
Or you can modify ssl_tls1.h, line 80.Code: Select all
Thx
Hi jackon,
I use the patch and in SDK 0.9.5_b1 to connect ssl server(111.206.227.37:2001), still find some problems:
connected with LU, channel 6
dhcp client start...
ip:192.168.2.114,mask:255.255.255.0,gw:192.168.2.1
user_esp_platform_dns_found 111.206.227.37
user_esp_platform_connect
espconn_ssl_connect 0x3fff5a30 0x3fff59d0 25352
espconn_ssl_client ssl_ctx 0x3fff5d20
send_raw_packet pkt_size 56
send_raw_packet Length 56
espconn_ssl_csent 0x3fff5a30 0x3fff5dec 56
espconn_ssl_crecv 409 0x3fff5dc0 0x3fff59a8
basic_read 1366 16 0x00000000
do_clnt_handshake: 107 2
do_clnt_handshake: 107 11
Error: Invalid X509 ASN.1 file (X509 not ok)
[D],process_certificate,x509_new
send_raw_packet pkt_size 7
send_raw_packet Length 7
client handshake failed
espconn_ssl_cclose 0
espconn_ssl_cclose_cb 10 0
user_esp_platform_discon_cbCould you help me to slove the problems ? This is very important to me.
Thanks!
