How To Connect to a Public IP
lfm_
Postby lfm_ » Wed Sep 06, 2017 8:40 pm
I'm trying to make a connection on my public IP and I'm not getting it, but if I connect to a local machine, it works.
This is the code i am using:
internet.println("AT+RST");
delay(2000);
internet.println("AT+CWMODE=3");
delay(100);
internet.println("AT+CWJAP=\""+ network +"\",\""+ password +"\"");
delay(2000);
internet.println("AT+CIFSR");
internet.println(""AT+CIPSTART=\"TCP\",\""  + IP + "\"," + Port")
If I connect to a local IP, it works, if I try to connect to my server in the cloud the return is ERROR CLOSED.
What should I do?
Re: How To Connect to a Public IP
Postby pratik » Wed Sep 06, 2017 9:59 pm
You should directly try the website name instead of the IP address. If you use IP address, then the connection will be made with a device within the subnet (local addresses by default).
So instead of connecting to, for example, 192.168.1.104 @port: 80
You can try www.yourcloudserver.com @whichever port you want
lfm_
Postby lfm_ » Wed Sep 06, 2017 10:35 pm
Thanks for the answer...
I've also tried the website, however how much do I try this way returns DNS FAIL
Did I configure it wrong?
lfm_
Postby lfm_ » Thu Sep 07, 2017 2:29 am
After updating the firmware, the connection was possible through the public IP.
Thank you very much
Postby pratik » Thu Sep 07, 2017 2:38 pm
Ohh, probably a firmware issue with some old version. Glad it worked!
