os_printf with a char pointer parameter causes an exception
ddze7374
Postby ddze7374 » Wed Sep 13, 2017 10:28 pm
I am trying to debug some code and need to display the content of the char pointer. But everytime it gives an exception.
static void ICACHE_FLASH_ATTR someCb(const char *data){
   os_printf( "LED = %s", *data);
Fatal exception 28(LoadProhibitedCause):
epc1=0x40245abe, epc2=0x00000000, epc3=0x40246461, excvaddr=0x00000023, depc=0x00000000
ÿ
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
Is there a way to access the content of this pointer ?
By the way is there a downloadable xtensa-lx106-elf-gdb debugger ?
ddze7374
Re: os_printf with a char pointer parameter causes an exception
Postby ddze7374 » Thu Sep 14, 2017 1:10 am
Solved , the flash needs an access to the aligned data.
jcmvbkbc
Postby jcmvbkbc » Thu Sep 14, 2017 4:05 am
ddze7374 wrote:
ÿ
The call to os_printf should be
os_printf( "LED = %s", data);
without dereferencing data. Otherwise you use the value of the first character of data as a pointer, which points to 0x00000023 in your case (that's the value of excvaddr), which is wrong.
ddze7374 wrote:Solved , the flash needs an access to the aligned data.
The original problem doesn't seem to have anything related to data alignment.
ddze7374
Postby ddze7374 » Fri Sep 15, 2017 6:52 pm
jcmvbkbc,
you beleive I have not tried without the dereferencing "star"?
Only, I agree with you that does take the pointer, not the dereferenced value like I described.
But in either case did not work for me.
