ESP8266_NONOS_SDK_V1.2.0_15_07_03
Admin
Site Admin
Postby Admin » Fri Jul 03, 2015 9:36 pm
请勿使用本旧版本 SDK,建议使用 最新发布 SDK。
ESP8266_NONOS_SDK_V1.2.0_15_07_03 Release Note
1.TLS server disconnect to ESP8266 may cause crash. [孙新虎]
Optimization:
  1. Update SmartConfig to version 2.4 , corresponding to ESPTOUCH APP v0.3.4 (https://github.com/EspressifApp/), delete parameter "sc_type type" in smartconfig_start, SmartConfig type can be got automatically.
  2. Add parameter "sint16 freq_offset; " in structure "bss_info" to get AP's frequency offset.
  3. Folder "ld" is updated, please use the latest one (\esp_iot_sdk_v1.2.0\ld )
  4. Add UDP transparent transmission example in documentation "4B-ESP8266__AT Command Examples"
  5. Revise the scan issue that may cause Wi-Fi connection break.
  6. Add ESP-NOW function, more details in "Add APIs"
  7. Add WPS function,more details in "Add APIs"
  8. Fixed a DNS fail issue with special router
  9. ESPCONN enter sent callback late in UDP transmission
  10. ESPCONN TCP shakehand may fail issue
  11. ESPCONN SSL connection fail may cause crash
  12. ESPCONN optimize SSL error handler
  13. Memory optimization
Add APIs:
1.ESP-NOW APIs
esp_now_init: init ESP-NOW function
esp_now_deinit: deinit ESP-NOW function
esp_now_register_recv_cb: register ESP-NOW receive callback
esp_now_unregister_recv_cb: unregister ESP-NOW receive callback
esp_now_send: send ESP-NOW packet
esp_now_add_peer: add an ESP-NOW peer
esp_now_del_peer: delete an ESP-NOW peer
esp_now_set_self_role: set ESP-NOW role of device itself
esp_now_get_self_role: get ESP-NOW role of device itself
esp_now_set_peer_role: set ESP-NOW role about another device
esp_now_get_peer_role: get ESP-NOW role about another device
esp_now_set_peer_key: set ESP-NOW key of a device
esp_now_get_peer_key: get ESP-NOW key of a device
2. WPS APIs
wifi_wps_enable : enable WPS function
wifi_wps_disable: disable WPS function
wifi_wps_start: start WPS communication
wifi_set_wps_cb: set WPS callback
3.software watchdog APIs
system_soft_wdt_stop: stop software watchdog
system_soft_wdt_restart: restart software watchdog
4.sntp_get_timezone: get SNTP timezone
AT_v0.30 Release Note:
Note: For AT firmware to support FOTA, flash size need to be 1024KB or more than that.
1.Command "AT+CWSTARTSMART" need not parameter any more, SmartConfig type can be got automatically.
2.AP's frequency offset can be got by command "AT+CWLAP"
3.Memory optimization
自从乐鑫信息科技于 2015-03-20 启动 Bug 赏金计划以来,我们收到了一些重要问题反馈及建议,感谢世界各地的开发者对 ESP8266的关注,推动我们的软件更进一步,技术支持团队也得到迅速地成长。我们将在如下发布日志中点名感谢您的帮助。
修正问题(符合乐鑫 Bug 赏金计划):
1.TLS server 主动断开连接导致崩溃的问题. [孙新虎]
优化:
1.更新 SmartConfig 到版本 v2.4 ,请对应使用 ESPTOUCH APP v0.3.4 (https://github.com/EspressifApp/)
SmartConfig 删除了接口 smartconfig_start 中的参数"sc_type type", SmartConfig 的类型可自动获得,无需再设置。
2.结构体"bss_info"中增加参数 "sint16 freq_offset",可获得 AP 的频偏值
3.更新了文件夹 "ld", 请更新使用最新的 ld 文件( \esp_iot_sdk_v1.2.0\ld )
4.文档 "4B-ESP8266__AT Command Examples" 中增加 UDP 透传的使用示例
5.修正扫描附近 AP 可能导致 Wi-Fi 断开的问题
6.新增 ESP-NOW 功能,详细内容见 "新增 APIs"
7.新增 WPS 功能,详细内容见 "新增 APIs"
8.修正特殊路由下 DNS fail 的问题
9.优化 espconn 修复以下问题:
(1) UDP SEND OK回复慢的问题
(2) 某些服务器 TCP 握手失败的问题
(3) TLS server 主动断开连接导致崩溃的问题.
(4) 优化TLS server主动断开连接与接收数据出错的处理
10. 内存优化
新增 APIs:
1.ESP-NOW APIs
esp_now_init: 初始化 ESP-NOW 功能
esp_now_deinit: 卸载 ESP-NOW 功能
esp_now_register_recv_cb: 注册 ESP-NOW 收包回调
esp_now_unregister_recv_cb: 注销 ESP-NOW 收包回调
esp_now_send: 发送 ESP-NOW 数据包
esp_now_add_peer: 增加 ESP-NOW 关联设备
esp_now_del_peer: 删除 ESP-NOW 关联设备
esp_now_set_self_role: 设置自身的 ESP-NOW 角色
esp_now_get_self_role: 查询自身的 ESP-NOW 角色
esp_now_set_peer_role: 设置指定设备的 ESP-NOW 角色
esp_now_get_peer_role: 查询指定设备的 ESP-NOW 角色
esp_now_set_peer_key: 设置指定设备的 ESP-NOW 密钥
esp_now_get_peer_key: 查询指定设备的 ESP-NOW 密钥
2. WPS APIs
wifi_wps_enable : 使能 WPS
wifi_wps_disable: 去能 WPS
wifi_wps_start: 开始 WPS 交互
wifi_set_wps_cb: 设置 WPS 回调
3.软件看门狗 APIs
system_soft_wdt_stop: 停止软件看门狗
system_soft_wdt_restart: 重新启动软件看门狗
4.sntp_get_timezone: 查询 SNTP 时区
注意:运行 AT 固件,支持云端升级,请使用 1024KB 或以上容量的 flash
1.指令"AT+CWSTARTSMART" 不需要再设置参数,SmartConfig 的类型可自动获得,无需设置。
2.指令"AT+CWLAP" 可获得扫描到的 AP 频偏值
3.内存优化
esp_iot_sdk_v1.2.0_15_07_03.zip
(11.71 MiB) Downloaded 23861 times
Re: ESP8266 SDK(esp_iot_sdk_v1.2.0_15_07_03)
Postby ESP_Faye » Wed Jul 08, 2015 11:14 am
Documentation "2C-ESP8266__SDK__Programming Guide" updates:
Don’t call espconn_disconnect (or espconn_secure_disconnect) to break the TCP connection in any espconn callback.
If it is needed, please use system_os_task and system_os_post to trigger the disconnection ( espconn_disconnect or espconn_secure_disconnect).
文档 "2C-ESP8266__SDK__Programming Guide" 更新:
请勿在 espconn 任何回调中调用 espconn_disconnect ( 或者 espconn_secure_disconnect) 断开连接。
如有需要,可以在 espconn 任何回调中使用触发任务的方式 ( system_os_task 和 system_os_post) 调用 espconn_disconnect ( 或者 espconn_secure_disconnect) 断开连接。
2C-ESP8266__SDK__Programming Guide__EN_v1.2.0.pdf
(964.49 KiB) Downloaded 7732 times
2C-ESP8266__SDK__Programming Guide__CN_v1.2.0.pdf
(1.31 MiB) Downloaded 3337 times
